Guest Guest_Leo_*
Squeaking Sound From Front End..
Guest Guest_Leo_*
Guest Guest_Leo_*
w=i changed my struts to bilstein touring. im getting a loud squeaking sound when i drive slow wit hbumps or make a turn with bumps. can my ball joints be going bad? I tightened everything up new links new bearing /strut tower mounts still the same problem.
macmom    0
I had the samething happen on my 95 850 when we did the suspesion with bilsteins and TME's back in 2000 it eventually will go away just the new stiffness.
Guest Guest_Leo_*
Guest Guest_Leo_*
its been a year nd still the noise..how long till it breaks in?
Serge    458
Check your spring mounts, sway bar links, everything. Make sure everything is tight and solid.
BrickLayer    0
I just fixed this problem on my 850 yesterday. and I use fix very loosely.what I did to stop the squeeking is spray the top of the suspension in the engine with a heavy duty lube. squeek is gone. but now I can hear the ticking in my engine..... you win some you loose some! now if they they had a can to fix that! but do not take this as a perminant fix. it is mostly likely your spring seats. and should be replaced. it helps on the ears though.
