Before:
After:
All you need is:
1) Black high temp paint
2) Q-Tips or small paint brush
3) Rubbing alcohol
4) A bowl to spray the paint into, so you can dip the Q-Tips
5) Socket wrench with 10mm socket
6) Flat head screwdriver
7) A beer
Ok so lets start.
Step 1: Take flathead screw driver...and push down tab on the back of the corner marker, it might be a bit tricky...but push the tab down and pull the corner towards you slowly.
Step 2: Pull the corner marker out
Step 3:Turn bulb holder/wiring to disconnect the bulb from the Corner
Step 4: Un-screw the 3 bolts attaching headlight housing to the frame
Step 5: Pop off both light covers (one unscrews, and the other snaps right off)
Step 6: After unscrewing light covers, disconnect the headlight bulb...and remove whole headlight from the car
Step 7:After removing headlight, locate the 7 tabs on all ends of the headlight (2 ontop, 1 on each side, and 3 on the bottom)
Step 8: Use flathead screwdriver to remove clips. I found it easier to pull up on the back part of the tab, pulling it up/toward me
Step 9:Pry glass lense from the housing...and using the Q-tips, use rubbing alcohol to clean the areas you want to paint black. Let the RA dry, and begin to apply coats of black paint using either a small brush or Q-tips like i did. The final outcome should look something like this when its finished being painted. From there, just go backwards with the steps you just did, you are all done!
A couple extra pics....
Any questions...feel free to shoot me a PM.
Edited by Mattphi, 03 March 2007 - 01:56 AM.
This topic is locked
