Wiring Info For Manual Swap
9 replies to this topic
#1 Markymark
Markymark
  • 492 posts
Posted 22 March 2007 - 01:19 AM
anyone who knows about the wiring please help with how its done. Anything helpfull onhow to do it with the Pnp switch, abs sensor for speed (i have a 95 850 turbo and donor car is a 93 N/A) im assuming i wil have to get the speed signal from the ABS sensor? also how to wire the reverse lights and really anything else involved with the swap other than the general hooking up the trans to my engine and all that stuff. any help is greatly appreciated as i am finally getting close to school being done and hopefully will finally make this happen.
I looked in the write ups but they were all basically how to do the general swap nothing specific as to wiring..
Thanks!,
Mark
95' 850 T5M
#2 Gilhuly
Gilhuly
  • 1,514 posts
Posted 22 March 2007 - 03:49 AM
It's all here. pretty far in
Doug's T5R buildup and manual swap
QUOTE(Markymark @ Mar 21 2007, 09:19 PM) View Post
Thanks!,
Mark
#3 yangotang
yangotang
    yangbang!
  • 6,890 posts
Posted 22 March 2007 - 03:52 AM
QUOTE(Markymark @ Mar 21 2007, 06:19 PM) View Post
Thanks!,
Mark
If your donor car is a MY93, you shouldn't have a problem with the speed sensor because it didn't change (at least to my knowledge) until MY96. The MY95 and lower cars had the speedsenor built into the tranny. You shouldn't need to modify anything in terms of the speedo sensor.
Basically, you need to modify the wiring on the bundle which forms the female side of the automatic transmission harness (the other male side stays with the transmission). Short circuit the two big solid green wires (there will be a few in the bundle, but there are exactly two which are ~12 gauge wire which are for the terminals for the PNP switch). This will fool the car into thinking that your car is always in neutral and allow it to start.
For the reverse light, there are also two big solid blue wires (~12 gauge), which are to be attached to the reverse light switch on the top of the transmission.
There's a write-up somewhere on http://rkforum.boardsxp.com/ , but I can't seem to get it up at the moment.
Hope this helps!
Edited by yangotang, 22 March 2007 - 03:55 AM.
Alex
2013 C30 T5 R-Design - Rebel Blue - Polestar Tuned
Old/Parting: '98 V70R AWD FWD - M56L - 19T - TT - RICA - 17" Team Dynamics Motorsport - Pro Race 1.2 - 18" Pegs - CJ Porsche 993TT BBK - CarPc - Parts For Sale - Click Me!
#4 Markymark
Markymark
  • 492 posts
Posted 22 March 2007 - 04:22 AM
QUOTE(Gilhuly @ Mar 22 2007, 03:49 AM) View Post
Yeah i have run across that thread before, i just read it again and correct me if im wrong but doug rewired his harness to be a manual one. This is not necessary and i would like to avoid it if i can. plus i couldnt find anything about taping into the ABS sensor or rewiring the Pnp switch or reverse lights other then if i wanted to change my harness to a MT one.
-Mark
95' 850 T5M
#5 Markymark
Markymark
  • 492 posts
Posted 22 March 2007 - 04:24 AM
QUOTE(yangotang @ Mar 22 2007, 03:52 AM) View Post
Hope this helps!
Thanks alot! thats exactly the kind of info i have been looking for!
95' 850 T5M
#6 Keaton85
Keaton85
  • 7,502 posts
Posted 22 March 2007 - 05:30 AM
You have to cut a wire for the cruise control also... i dont have a clue what the wire is because i never did it since i didnt touch the cruise control. I wouldnt mind knowing though just in case the guy i sold the car to calls me up asking why it doesnt work haha. anyone?
#7 yangotang
yangotang
    yangbang!
  • 6,890 posts
Posted 22 March 2007 - 06:30 AM
QUOTE(binglax09 @ Mar 21 2007, 10:30 PM) View Post
hmm, i'll look into some wiring diagrams and see what i can come up with. though IIRC it's an ECU issue.
Alex
#8 Boomin850
Boomin850
    Socal Rod Bender
  • 4,486 posts
Posted 22 March 2007 - 06:42 AM
QUOTE(yangotang @ Mar 21 2007, 08:52 PM) View Post
lolwut
#9 98s70t5
98s70t5
  • 473 posts
Posted 22 March 2007 - 06:46 AM
QUOTE(Boomin850 @ Mar 21 2007, 11:42 PM) View Post
I think you have me confused with Grant cuase i definately do not go for bros. Plus alex is to easy, i go for the hard to obtain men like you. biggrin.gif
1998 S70 T5 Black on Black
Black projectors, xc grill, 18" Pegs, HIDs
#10 yangotang
yangotang
    yangbang!
  • 6,890 posts
Posted 22 March 2007 - 06:48 AM
QUOTE(98s70t5 @ Mar 21 2007, 11:46 PM) View Post
I think you have me confused with Grant cuase im definately do not go for bros. Plus alex is to easy, i go for the hard to obtain men like you. biggrin.gif
lol.
Alex
