What Affects Ohms
5 replies to this topic
#1 ProjectT-5R
ProjectT-5R
  • 871 posts
Posted 14 August 2004 - 08:29 PM
What controls what ohms an amp or speaker runs at. I am looking at amps and most have ratings for 2 or 4 ohms. So is that determined by what the speaker draws or is it determined by what you set them amp to? I am a bit confused.
Todd
2000 V70R M56
1995 T-5R M56
1989 244 M47
1985 744T M46
#2 AnthonyR
AnthonyR
  • 1,437 posts
Posted 14 August 2004 - 08:35 PM
It is determined by the speakers or subs you are connecting it to. If the amp has ratings for 2 and 4 ohms usually the 2 ohm has a bit more power. Most standard subs are 4ohms. Connect 2 of them in parrellel, (hooking both positives to the positive on the amp and both negatives to the negative on the amp would give you 2 ohms (it divides in parrallel, and adds in series (series is where you hook the positive on one sub to the positive on the amp and the negative on the other sub to the amp and connect the negative of the first sub to the positive of the other sub) with 2 4ohm subs in series would give you 8ohms. Confusing? yes of course at first tongue.gif
-Anthony Randall
OH Moderator
2001 BMW 525i
1996 Volvo 850 - Not running and in pieces! Project for my lil sis!
#3 ProjectT-5R
ProjectT-5R
  • 871 posts
Posted 14 August 2004 - 09:11 PM
do speakers ever run anything other then 4 ohms?
2000 V70R M56
1995 T-5R M56
1989 244 M47
1985 744T M46
#4 mAydAy
mAydAy
    Team Spec Clutch
  • 1,466 posts
Posted 14 August 2004 - 09:33 PM
Speakers will sometimes run 8ohm and I've seen some run 6ohm in home audio stuff.
-Andy
1998 V70XC
1994 850T
1994 850 NA 5spd
#5 AnthonyR
AnthonyR
  • 1,437 posts
Posted 15 August 2004 - 04:14 AM
QUOTE(ProjectT-5R @ Aug 14 2004, 04:11 PM)
speakers can run just about anything, but typically car audio speakers run at 4 ohms. Then you also get into dual voice coils. Like my IDQ's are dual 2 ohm, so the one speaker has two seperate 2ohm coils that have to be wired to either one or 4 ohms tongue.gif
-Anthony Randall
OH Moderator
2001 BMW 525i
#6 JPigg34
JPigg34
  • 265 posts
Posted 29 August 2004 - 07:56 PM
I know this topic is about a 3 weeks old, but here is a site that helps determine impedence. Wiring Help It has helped me many times.
Edited by JPigg34, 29 August 2004 - 07:57 PM.
John
1996 854 NA
Audio: XM, Alpine Type-S speakers in the front doors
