I plugged the leads of some little LED sized lamps into the speaker terminals of my sub and they are pretty cool. It is a cheap and easy way to have some lights that go with the bass and I have a switch wired in so that whenever I don't want them, they're off. I'm not sure what any negatives might be though, I can't tell any difference in sound, but let me know if you can think of a negative.
Subwoofer Lights
Started by nagrod18, Aug 24 2004 05:03 AM
4 replies to this topic
Posted 24 August 2004 - 11:58 AM
You may be affecting the impedance load that your amp is seeing. If you have a decent quality amp, and aren't running too many speakers with it, then this shouldn't be a problem.
-Chris
-Chris
Posted 24 August 2004 - 01:30 PM
the only issues i may see is as chris said, impedance issue, also, sometimes it could cuase a ground loop and induced noise but you seem to be fine... the only time i did something similiar i went and got a cheapo kraco amp from walmart, hooked it up, and hten use this thing to exclusiveply power some led bars...worked out okay (it wasnt my idea), so... i think you should be fine
b
b
Fully authorized Dealer: Image Dynamics - DLS - Elemental Designs
