Antenna
5 replies to this topic
#1 nagrod18
nagrod18
  • 127 posts
Posted 25 August 2004 - 09:18 PM
The antenna on my 850 is currently stuck in the up position. I am sure it is my fault, because it used to only stick out about 6 inches once in the down position and I hated it so I just pushed it in. After that, once it was out, it stayed out. I can hear the antenna try and move when I turn the radio on or off, but it only moves an inch or two. I want to fix this, would it just need a new antenna or could I have messed something else up, like the motor?
#2 Veneficus
Veneficus
    biggie
  • 6,066 posts
Posted 26 August 2004 - 12:25 AM
Take apart the pannel where the antenna is and check to make sure the white strip that connects to the motor is catching. Rich has a write up on how to replace them here. Also you may need a new mast. Link here.
- Captain John Paul Jones
#3 VS Legend
VS Legend
  • 6,824 posts
Posted 26 August 2004 - 04:04 AM
Hey man, at least you didn't have to start this thread, "I can't get it up!"
2007 Volvo XC70 Daily Driver Steel Cargo Barrier (+50HP), Cargo Cover (+30HP), Bluetooth (+5HP), iPod Dock (To Be Installed, +15HP)
1995 Volvo 850 T-5R Currently in Storage RWD Conversion, 8-Speed Automatic Conversion, Quadruple Turbo w/ Supercharger and NOx
#4 Burgundy_850
Burgundy_850
  • 365 posts
Posted 26 August 2004 - 07:08 AM
check to make sure the mast is straight by holding something straight next to it. if it's not, you can gently bend it back into shape. also rotate each section with plyers on cloth to make sure they can move freely where they slide into each other and aren't clogged with dirt.
user posted image
#5 s40euro
s40euro
  • 768 posts
Posted 26 August 2004 - 08:10 AM
If it is not mast then unassamble the whole staff and remove the small electric engine.
Check the brushes and the rotor for dirt. Clean them with some degraser staff.
It happened to me last month and I almost was going to purchase the whole darn new anntenna assembly which is quite expensive
<!--coloro:#000099--><span style="color:#000099"><!--/coloro--><!--sizeo:5--><span style="font-size:18pt;line-height:100%"><!--/sizeo--><!--fonto:Courier--><span style="font-family:Courier"><!--/fonto-->2000 V70 T5 Auto @90K Km. full stock.At <strike>the dealer for a rebuilt</strike> home <!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc-->
Euro spec Clear Headlight + Turn Signals+Strut Brace+Engine Protection Plate has arrived and <strike>waiting to be</strike> installed
#6 nagrod18
nagrod18
  • 127 posts
Posted 01 September 2004 - 12:50 AM
thanks for all the replies they were all very helpful. I finally got around to checking out the antenna, I straightened it as best I could and made sure each segment could move freely. Then I took the mast out and made sure the white strip was catching on the motor (which was a huge pain). I got it to go back in and then I got it up too biggrin.gif, but when it went down about six inches stayed out. Would I screw it up if I just cut about six inches off of that white strip? or should I just get a new mast? or what?
