Unhooking Power To Antenna
12 replies to this topic
#1 Pete D
Pete D
  • 82 posts
Posted 27 August 2004 - 06:20 AM
My antenna mast is screwed up and won't extend all the way unless I pull it up by hand. This is fine of course until I shut the car off. I'm looking for a way to disconnect the motor to the antenna. I suppose I could just snip the lead from the HU that triggers it, but I would rather not cut the wires if I don't have to. I pulled away some of the trunk lining but didn't see any particular connectors to unplug. Any tips would be very apreciated.
user posted image
Former Owner: 96 854TLA "Platinum Limited Edition"
#2 potroast
potroast
  • 585 posts
Posted 27 August 2004 - 06:45 AM
a new mast is $40 if you thought it was expensive.
if you peel the carpet back by the mast you will see the wiring harness between the mast and rear seat. Grey with blue stripe I believe is the wire you want.
#3 Veneficus
Veneficus
    biggie
  • 6,066 posts
Posted 27 August 2004 - 01:49 PM
You don't necessarily have to pull out just the antenna line, you could just unplug it alltogether, unless you still want your radio to pick up stations that are about 3 miles away... huh.gif
- Captain John Paul Jones
#4 AnthonyR
AnthonyR
  • 1,437 posts
Posted 27 August 2004 - 02:07 PM
Just unplug the harness that goes to the motor (3 wires in that one I believe) that's what I did with mine as mine would always get stuck and I have sat radio now anyways. also the actual antenna will still be connected as that connects higher in the mast, but it just won't go up and down and that's what you're looking for I think
-Anthony Randall
OH Moderator
2001 BMW 525i
1996 Volvo 850 - Not running and in pieces! Project for my lil sis!
#5 Modus
Modus
  • 693 posts
Posted 27 August 2004 - 02:13 PM
I have antenna problems too, unhooking it would poberly be the best bet. But to fix the antenna when it doesn't go down or up any more, Get a towel cup your hand and spray some lubricant wd-40, silicon spray, ect up and down the antenna. ( so you don't have to wash your car afterwards) Next pull the antenna up and down by hand carfully not to bend. Spray more lube. It should free up any hardend greese that's in the pully case.
For me this lasts for about 2 months then you have to redo the process over again.
#6 Mesoam
  • 18,673 posts
Posted 27 August 2004 - 02:43 PM
you could try this
Antenna Switch
96 854 R, CLICK ME
The Jeep
#7 JehovArob
JehovArob
  • 1,941 posts
Posted 28 August 2004 - 04:38 PM
This is part of the reason I like my aftermarket headunit. I don't listen to the radio, only CDs, and it doesn't put the antenna up unless the radio is on. So, no need to worry.
#8 Serge
Serge
    Level 6 Senior Member
  • 10,667 posts
Posted 28 August 2004 - 06:50 PM
QUOTE(AnthonyR @ Aug 27 2004, 08:07 AM)
Exactly what I did. It looks better driving around w/o an antenna up anyway =]
Plus, I don't listen to the radio.
Serge - 95 850 T5
#9 Guest_Guest_*
Guest_Guest_*
Posted 30 August 2004 - 05:30 AM
QUOTE(AnthonyR @ Aug 27 2004, 02:07 PM)
Thanks guys, found the plug and unplugged it!
#10 Guest_Guest_*
Guest_Guest_*
Posted 02 September 2004 - 03:49 AM
Sorry...but where can I find the harness that goes to the wire and which wires should I be looking for? Thanks!
#11 Veneficus
Veneficus
    biggie
  • 6,066 posts
Posted 02 September 2004 - 11:06 AM
QUOTE(Guest @ Sep 1 2004, 11:49 PM)
The radio harness that you're looking for is located in the back left side of the trunk. There will be a pin that holds the pannel back so get a flathead screw driver and take that off. After doing that locate your antenna and you will see a black block comming off of it. If you want to disable the antenna, you will see a thick red line (the stable power) and then a smaller thinner red or blue line (don't quite remember which it is) that will also feed into the harness. This is the wire that you want to clip if you want to disable the radio. However, rather than cutting wires, just unplug the harness, so if at some point you do want to listen to the radio you can plug the harness back in.
#12 s40euro
s40euro
  • 768 posts
Posted 02 September 2004 - 12:14 PM
QUOTE(Pete D @ Aug 27 2004, 01:20 PM)
Check this Topic
<!--coloro:#000099--><span style="color:#000099"><!--/coloro--><!--sizeo:5--><span style="font-size:18pt;line-height:100%"><!--/sizeo--><!--fonto:Courier--><span style="font-family:Courier"><!--/fonto-->2000 V70 T5 Auto @90K Km. full stock.At <strike>the dealer for a rebuilt</strike> home <!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc-->
Euro spec Clear Headlight + Turn Signals+Strut Brace+Engine Protection Plate has arrived and <strike>waiting to be</strike> installed
#13 Guest_Taylor_*
Guest_Taylor_*
Posted 06 September 2004 - 11:32 PM
There's no reason to disconnect wires. Just take out the fuse for the antenna.
