2000 S40 Cylinder Ii Misfiring With Cel P0302
19 replies to this topic
#1 Guest_Veeru_*
Guest_Veeru_*
Posted 26 September 2007 - 06:25 PM
Yesterday I got a check engine light and the car is loosing power at 0-15 mph speed. Some times when moving from redlight, check engine light is flashing and it's changing to constant light after 25 mph.
Today I checked the CEL at autozone and it came out as P0302 misfiring 2nd cylinder. The car had original plugs and wires. Few months back, it got starting problem, which got resolved with replacing Fuel pressure regulator. Dealer also suggested to change MAF (Mass Air flow), which I rejected.
Does any one have suggestings before I hit that dealship?
Thanks,
Veeru
2000 S40 with 68k miles (II owner)
#2 Guest_850T-5_*
Guest_850T-5_*
Posted 26 September 2007 - 06:44 PM
Replace plugs with Genuine OEM Volvo Plugs, they work the best guaranteed, many aftermarkets, especially BOSCH cause problems or fail prematurely.
There aren't any wires, just coil packs so while replacing the plugs, I'd swap the middle coil packs while your at it and reset codes.
If it comes back and is now on another cylinder that coil pack is more than likely bad and needs to be replaced. If the problem goes away a spark plug went bad, which can happen.
#3 theForgottenone
theForgottenone
  • 4,133 posts
Posted 26 September 2007 - 07:33 PM
QUOTE(Veeru @ Sep 26 2007, 11:25 AM) <{POST_SNAPBACK}>
Thanks,
Veeru
68K on original spark plugs?
btw, we do have two coil packs and two spark plug wires. Replace with OEM spark plugs first or NGK brand.
#4 Guest_Veeru_*
Guest_Veeru_*
Posted 26 September 2007 - 07:51 PM
QUOTE(theForgottenone @ Sep 26 2007, 07:33 PM) <{POST_SNAPBACK}>
I am not 100% sure, but when I asked the previous owner about what was changed, he said nothing except battery tires and brakes. So I thought the car was so good and bought it right away at 60 K miles last year.
In last 12 months I ended up paying $2000 for small stupid problems at dealership.
Thanks for the replies and I will try getting changed plugs first.
Thanks,
Veeru
#5 theForgottenone
theForgottenone
  • 4,133 posts
Posted 26 September 2007 - 07:54 PM
QUOTE(Veeru @ Sep 26 2007, 12:51 PM) <{POST_SNAPBACK}>
Thanks,
Veeru
Browse s40concepts.net on How-to section for serveral maintenance procedures.
#6 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,925 posts
Posted 27 September 2007 - 01:39 AM
I bet you need a coil, they go out quite a bit.
Sonic Shenanigans
#7 Guest_Veeru_*
Guest_Veeru_*
Posted 28 September 2007 - 03:11 PM
For the time being the problem was gone after adding a bottle of Fuel Injection Cleaner and changing to 93 octane gas, now CEL and misfiring both gone. I am always using 87 octane, and a friend of mine advised to change it to high octane gas and a bottle of Fuel Injection cleaner before going to dealer, which worked perfectly.
Many Thanks for the advices.
Veeru
#8 theForgottenone
theForgottenone
  • 4,133 posts
Posted 28 September 2007 - 03:14 PM
QUOTE(Veeru @ Sep 28 2007, 08:11 AM) <{POST_SNAPBACK}>
Veeru
Please tell me you gonna change the spark plugs! Nobody in the right mind run regular on a turbocharged car? They require premium gas from the factory.
#9 Guest_Veeru_*
Guest_Veeru_*
Posted 28 September 2007 - 03:35 PM
QUOTE(theForgottenone @ Sep 28 2007, 03:14 PM) <{POST_SNAPBACK}>
Nope, What I said was 100% TRUE. I am always using 87 octane from last one year (I am 2nd owner), and I don't have knowledge to use high octane on Turbo charged engines, until my friend mentioned it.
Thanks,
Veeru
#10 theForgottenone
theForgottenone
  • 4,133 posts
Posted 28 September 2007 - 03:38 PM
QUOTE(Veeru @ Sep 28 2007, 08:35 AM) <{POST_SNAPBACK}>
Thanks,
Veeru
Well, even though you run premium gas now, you still need to change the spark plugs as it got 68K miles on it already.
#11 2001T5
2001T5
  • 263 posts
Posted 28 September 2007 - 03:43 PM
That could be most of your problem. Try to stay away from Wawa and Sheetz also. (if you have those near you). They both sell reserve gas, and it's brutal on a lot of cars.
Eamen
2001 V70 T-5
Upgrades ~ IPD upper/lower poly engine mounts, EST CAI, IPD TCV, Stylin Hoses vacuum hoses, Bilstein HDs with TME sport springs, IPD swaybar end-links, Stealth tint. Tinted wagons rule!!
#12 Guest_Veeru_*
Guest_Veeru_*
Posted 28 September 2007 - 04:18 PM
QUOTE(theForgottenone @ Sep 28 2007, 03:38 PM) <{POST_SNAPBACK}>
Sure, I am planing to schedule a dealer 60K service. I think my self and my previous owner, both are so lazy on maintenance. Previous owner a lawyer Kept the car on street for 3 months with out running (since he bought a benz) and when I first saw, couple of tires were flat and it is so dirty. Since there are no blemishes and when I started engine, it ran smooth and I took it with out any hesitation). He said it was ran good and nothing changed from new other than regular items like tires, brakes and a battery. He didn't mentioned to me about high octane fuel, so I am simply using regular gas. It's my bad on not knowing the facts about the car.
Now on I will follow Service manual maintenance.
Many thanks,
Veeru.
#13 theForgottenone
theForgottenone
  • 4,133 posts
Posted 28 September 2007 - 05:06 PM
QUOTE(Veeru @ Sep 28 2007, 09:18 AM) <{POST_SNAPBACK}>
Many thanks,
Veeru.
Dont' go to dealer for 60K service....you can do all of that yourself. All you need to do is drain/fill transmission fluid, coolant, oil, new spark plugs, spark wires, air filter, cabin filter. Then you are good to go.
Everything I have mention can be done at your driveway. I have mention a website for procedures and pictures wink.gif
#14 Guest_Veeru_*
Guest_Veeru_*
Posted 06 October 2007 - 05:53 PM
QUOTE(theForgottenone @ Sep 28 2007, 05:06 PM) <{POST_SNAPBACK}>
Today the CEL came again with that occational misfire. At last I dared to open the hood and open that plastic cover and it seems to me the engine oil spill over the plug wires and further there is small oil went inside the spark plug hole (first cylinder hole on passenger side). Also the shield over the wires was so brittle and most of it's now like small bits and pieces all over that place. I open the 2 easy plug wires and see some oil in one plug hole with those broken shield pieces. I didn't open the plugs, since I am afraid that small particles may get inside. I tried my best to clean the holes for oil and pieces (with vacum cleaner).
After your boost on DIY, now I feel confident to do it.
Now I have few questions.
1. How to find out the cynlinder #2, which caused misfire (P0302).
2. I see oil spill on first cylinder from passenger side (near right tire)
3. At what mileage coil packs should be replaced
Do you think It's ok to change the plugs, or I should take it to the dealer for cleaning oil professionally before placing new plugs?
Thanks,
Veeru
#15 2001T5
2001T5
  • 263 posts
Posted 06 October 2007 - 06:10 PM
We at Advance Auto Parts usually only recomend changing faulty coil packs. So like 850T-5 said, switch the suspect coil pack with one from a cylinder that isn't throwing a misfire code, erase the codes, and see if the problem follow the coil pack. If it does, just replace that one, with all new plugs. As for the wire loom, use a light and make sure you get all of it out of the spark plug hole.
Eamen
2001 V70 T-5
#16 Guest_850T-5_*
Guest_850T-5_*
Posted 07 October 2007 - 04:19 AM
For the oil under the spark plug cover, I would
1. Replace the PCV fitting on the AMM to Turbo hose
2. Replace the Oil Cap Seal, dab a little oil on the new seal though to prevent it from drying out.
Make sure the cap feels fairly secure after.
3. Clean everything up best you can with spark plug wire boots all install not to spill anything down there.
4. Change Plugs
5. Try Swapping Coil Packs as mentioned
or hit up the dealer and pay some scrill if you don't feel comfortable.
Edited by 850T-5, 07 October 2007 - 04:19 AM.
#17 Guest_Veeru_*
Guest_Veeru_*
Posted 09 October 2007 - 12:11 AM
QUOTE(850T-5 @ Oct 7 2007, 04:19 AM) <{POST_SNAPBACK}>
4. Change Plugs
Hi,
While I am removing wires from coils, I forgot to note the order with my stupidity. Now I am in confusion to put which wire to which coil. As I don't have any manual, my only way is this forum. So could you please some one advise me the order of spark plug wire to coil connectivity.
From my memory, It looks to me that I saw 1 to 4 and 2 to 3.
Thank you in advance for the replies.
Veeru
#18 dmelviØØ7
dmelviØØ7
    Bi-Winning
  • 12,925 posts
Posted 09 October 2007 - 01:04 AM
The wires are numbered
Sonic Shenanigans
#19 Guest_Veeru_*
Guest_Veeru_*
Posted 09 October 2007 - 01:58 AM
QUOTE(dmelviØØ7 @ Oct 9 2007, 01:04 AM) <{POST_SNAPBACK}>
Yes, there are numbers on the wires, but from 1 number to which coil? (1st or IInd coil from driver side).
Is there any sequence or they (plug to coil) can be connected in any combination?
Thanks,
Veeru
#20 Veeru
Veeru
  • 5 posts
Posted 16 October 2007 - 03:07 PM
QUOTE (850T-5 @ Oct 7 2007, 12:19 AM) <{POST_SNAPBACK}>
4. Change Plugs
Well this is my First Job as DIY. This is of great help being answered.
Last weekend I replaced Spark Plugs, Wires and Coil Packs. Couple of Spark plugs were so dirty like tar and gap is so wide compared to the new plugs. Both Coil packs have straight cracks inside. It took me 3 hours to clean all the oil from the spark plug holes. Now the car runs smooth and all misfires gone.
While I am buying coil packs and wires, I confirmed with the dealer on the order of wires to coil packs connection, which is 1-4 and 2-3.
My sun visor on the driver side will no longer stay up. I just bought a new one from dealer ($85)
It looks like torn at the hinge, I opend the two screws and tried to pull it off gently with out success, so I don't know how to take it out. Any help on how to replace that would be greatly appreciated.
Thanks,
Veeru
