scout01
 Share
5 hours ago, Kevin. said:
interesting, as my co-worker got 18,300 miles out of his RE-11's and 18,800 miles on his RE-11A's. -1.8 degrees front and -1.3 degrees rear camber on his 1995 Acura Integra, he does have less caster than your M3 though.
Very Different tires.
Very very different cars.
caster will not cause tire wear..
the Type R seats though.. That's an important feature to point out when talkin  suspension and tires
come on Kevin.
Fwiw: my M3 is running -4C with 0 toe in front and -3C with .10toe in rear.
So a little more aggressive than someone else's integra..
Drivers front:image.jpeg
2 hours ago, Kevin. said:
you do realize most of the people on this forum have FWD cars, right?
Much to learn.
Also so you do realize this discussion was originally between Chris and myself, neither car is a fwd Volvo and we were discussing tires for non street use. As in a spare set for autoX and track.
right, so you have very aggressive camber and you track the car. He DD's the car and does spirited mountain driving on the weekends which would explain how he is getting the mileage he is. Saying you will get under 1,000 miles on those tires is very misleading
Kevin. What was the original discussion, Between Chris and I, about?
You know the one you interjected your genius into?
..And "He" isn't using RE71R either. So enough.
 Justifying your opinion by comparing different tires on a different car with a different alignment and a different use of the car,  without taking the context of the discussion to mind, so you can prove your genius..
  • Upvote 2
This is from the guy that uses DWS as winter tires IIRC...
M3 looks like it's doing what it was made for:tup:
Edited by ruecatinat
I can't type sometimes
 Share
