Mine is my daily which is now sitting at 301,000 miles on it.  I don't know about your garage queens.
I swapped the O2 sensor trying to solve a random issue when starting cold.
  • Replies 24.5k
  • Created
  • Last Reply
Top Posters In This Topic
  • matt b
    1494
  • 7 VII 7
    1133
  • Oreo931
    1091
  • Chilled man
    1062
Popular Posts
no because you cannot mesh T5 and Pole... too much of a "stretch" if you said "waxed my rocket" that would have been better
What are you raising it to?? I'm just throwing the MBC wide open. (Worse case, the ECU will get pissed and fuel-cut, but the tune should fix that.) I'm really interested to see how far that 15G can
Started it. Drove it.
Posted Images
Finally found a local clean replacement passenger fender that I picked last week. Installed this and swapped the jewel turn signal from the C70 into the S70 and installed a new one on the C70. Still need to do PDR on a couple small dents and then buff it up to be perfect.
Big thanks to Daniel who found this one.
Time to refresh the rear brakes on the S70 next as I discovered a sticky caliper. That’s next Saturday’s adventure.
I daily the S70 and now my oldest is learning to drive with it. Just hit 135k miles. I’ve put 9k miles on the coupe since I bought from Josh 9 years ago but the bulk of that was in the first 5 years.
  • 3 weeks later...
  • 4 weeks later...
UR 23mm rear sway bar.
I need to install the OBX exhaust and boost gauge on my next day off.
ipd springs, Koni oranges, UR 23mm rear sway bar, EST carbon strut brace. And I can't find any  of my old camber bolts.
Edited by CAAnglin
12 hours ago, Ihatespeedbumps said:
Installed Snabb short throw shifter and delrin bushings. Also installed ipd oval exhaust.
Edit; 5,000th post. Only took 12 years :a-farmboy:
How do ya like the shifter
Completely overhauled the rear brakes including parking brake.
F this spring.
Used up one of my last two cans of blue stuff.
5 hours ago, Ihatespeedbumps said:
Was driving the XC70 to work this morning in the rain. Accelerated around a corner, heard a loud bang and then the front wheels broke free. Stripped out the goddamn collar :angry:
Factory collar or had you already done work on it?
12 hours ago, quiksilver said:
And here I was, thinking stripped collars were almost solely an R problem.
Nah, I've put just as many collars on XC's as I have R's.
Factory collar. I needed to replace some of the angle gear seals anyways, so I guess no time like the present. I'm hoping the angle gear made it out ok though.
