scout01
Replaced the fuel pressure regulator trying to track down a problem.  That didn't fix it.  :(
What's going on?
When I start it cold, it sometimes acts like it is only firing on 3 cylinders, then slowly comes up to idle normally.  Not every time, but half the time.  AFR shows normal, it just doesn't run right the first 20 seconds or so.
Also, if it isn't warmed up, give it a little gas to start out and it wants to stall.  Once is starts to warm up, these problems go away.  The other issue is under boost it acts like it hits rev limiter at 4200-4500 RPM.  No boost you can get it to 5000.  Fuel economy sucks as well.  AFR under boost should be 11.3-11.5, but it is 12.1.  The tune wasn't set that lean.
Not a MAF or O2 sensor issue, ignition system is all new, even the coil.
George, I can’t remember, what injectors are you running?
Pressure was tested at the rail at idle and it was normal.   However, that testing was done a month ago and things have gotten worse since then.
Injectors are Bosch 630cc.
fuel pump? Had the same problem in my s70 na minus the AFR issues (obviously). Replaced fuel pump and all is well. I think I let the gas tank run too low too many times and it just slowly started to give out. I had that rough shitty idle at random start up (many times if I didn't drive it all weekend), but it would resolve itself, and sometimes wouldn't happen for weeks. Car started to completely cut off recently so I replaced the pump and that fixed it.
Well, the pump is next on my list.   It is a Walbro that I installed many years ago.
Tint. Already got hid's. Now to find an R bumper.
Also need to get the OBX tip shortened.
Still digging this car. Got it for 1k and just been putting old parts on it. :cool:
A while back I plasti-dipped the bumper grilles and put junk yard fogs in it.
Before someone had painted the grilles and fogs white.
Installed a brand new Walbro fuel pump last night.  Didn't fix my issue.   :(
No, but I have a new fuel pump relay I can swap in before going to work.  I will have to order the ignition relay.
Fuel pump relay didn't change anything.  I doubt ignition relay will either.
crush it?
jkjkjkjkjk
How long has this been happening?
Now I want a white S70... it looks awesome!
