scout01
Trade me you hoe.
Needs moar low hoe
oil change: did.
wash: did.
smiled at the complete lack of squeaks and rattles: check.
Finally changed the bumper.
282558_10150250036001966_508651965_75375
Wow! Bumper looks great mike! ^_^
Took the day off and autocrossed the car. :)
:lol: :lol: :lol:
Didn't take a pic when I got the new bumper because when I was done putting all my tools and stuff away, it was too dark!
Took her to the Carlsson show in Palo Alto. :)
Experienced what boost feels like in cooler temps (80ish) for the first time since wednesday.
god yesterday sucked. picked it up at 3:00 so hottest time of the day. :lol:
Cant get the T5R to spark :(
Replaced:
Cam pos
Crank pos
Ecu
coil
cooling fan relay <--- found out this was actually bad
The battery is weak now from all the cranking so I might give it another shot tomorrow. Anyone else have ideas?
Replaced:
Cam pos
Crank pos
Ecu
coil
When you have gone through all those, I start thinking; is the coil getting voltage? is it still when cranking? If not; you have covered the biggies but what about something semi mechanical like the ignition switch? Relays? (my 98 has those...)
Good luck
Good luck
I was thinking the same thing but after reviewing some wiring diagrams the fuel pump also gets its power from the ignition switch via the same blue/red wire. The power stage also has a ground and a signal from B11 on the ecu socket. I'm betting the ecu isn't seeing the proper signals to send the signal to the coil to fire.
Changed out the worn passenger side control arm. Decided to go with ScanTech instead of Genuine Volvo because of price. Let's hope it lasts for a decent amount of time. lol
  • Downvote 1
Took my front breaks apart lubed and replaced and finally installed the steel braided brake lines. while doing so discovered axle grease sprayed all over the drivers side. lol does anyone have a drivers side axle lying around they want to sale.
Started it up and let it run checking for any leaks, all is good. Just need to button up a few things and get her inspected now.
Lifters ticking from being dry for the first couple minutes of running made me :o :lol:
