Anti Skid Light On Xc 90
9 replies to this topic
#1 adjd1234
adjd1234
  • 3 posts
Posted 12 November 2007 - 09:42 AM
Hello, I'm a newbie fron New Jersey with a 2004 XC 90 problem.
My message center on my dash flashed " Service needed for anti skid mechanism". Just flashed once about a month and a half ago. Just that once. This was after I turned my car on after getting gas. Flashed once for a few seconds and haven't seen it since. I have 44K miles on the car.
Took car to dealer for scheduled service (Redbank Volvo) and happened to mention this. The next thing I know the "advisor" is telling me that I need to replace my ABS Module for $1250!!
What do you guys think? Any advise?
Can someone PLEASE give me an Indy Volvo mechs in Redbank or Freehold area please.
#2 PyROTech
PyROTech
  • 5,476 posts
Posted 12 November 2007 - 03:51 PM
QUOTE (adjd1234 @ Nov 12 2007, 04:42 AM) <{POST_SNAPBACK}>
goto a parking lot and drive fairly fast and mash your breaks. This will determine the abs, then if that works drive through a corner and mash the breaks again while trying to make the car spin out or you can just take corners in the rain and see if you start to spin. If all is good, then forget about the message, it would also be helpfull to read the codes and post them (i cant tell you what the codes mean but others can).
#3 adjd1234
adjd1234
  • 3 posts
Posted 13 November 2007 - 01:32 AM
QUOTE (PyROTech @ Nov 12 2007, 10:51 AM) <{POST_SNAPBACK}>
Whew, finally got back from work and have some time to read the forums!
Thanks for the info. I did try to mash the brakes in regular weather and alls fine. I haven't spun out in the recent NJ rains either. I will try the rain thing a bit more aggressively next time.
What do you mean by codes? Where do I get them? My message center just flashes the words, no codes.
Cheers and thanks!
#4 jhb8426
jhb8426
  • 83 posts
Posted 13 November 2007 - 04:19 AM
Sounds like early symptoms of ABS unit failure. If you're only getting this once in awhile it could go for quite some time. If you start getting this with ABS failure lights, it close to gone.
Currently: 2005 S60, 2006 V70 2.5T
Previously: 1996 850 wagon, 2000 S70, 2001 V70 2.4T
#5 D s50r
D s50r
  • 1,535 posts
Posted 15 November 2007 - 01:02 AM
NO its not the abs its your YAW sensor its under the passenger seat and u will find water under the carpet which is what made the YAW sensor go bad this past spring ive replaced 10 YAW sensors with the same problem
98 midnight blue s70 glt se
#6 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,905 posts
Posted 16 November 2007 - 07:31 PM
QUOTE (semir @ Nov 14 2007, 07:02 PM) <{POST_SNAPBACK}>
Possible cause, I've seen quite a few replaced. Call and talk with the service manager to see if they are sure $1300 will fix the car. If it dosen't you have lots of leverage.
#7 Arbelac
Arbelac
  • 146 posts
Posted 16 November 2007 - 07:43 PM
Maybe I'm dumb, but how is a 2004 not under warranty still? Or do the US models not have a 4 year warranty?
Blue 98 V70XC AWD, B5254T, 230,000KM
Black 01 V70T5 FWD, Manual 5 Speed, 206,000KM, QBM Strut Brace Conversion, QBM Poly Transmission Mount, Tom's HD Endlinks
#8 D s50r
D s50r
  • 1,535 posts
Posted 16 November 2007 - 09:58 PM
you are still under warranty if u have 44k on your car and its an 04 ............ and im 99% sure that its the YAW sensor if u can get me the code i can let you know 100 % what it is
Edited by semir, 16 November 2007 - 09:59 PM.
#9 xc90volvoguy
xc90volvoguy
  • 1 posts
Posted 28 November 2007 - 09:48 PM
QUOTE (semir @ Nov 15 2007, 01:02 AM) <{POST_SNAPBACK}>
I have an 04 xc90 with 40k miles. My wife spilt her water bottle on the passenger floor. Week later "anti skid service reqiured" Brakes work fine. I have heard that it my be the yaw sensor. The text window also displays 023. I'm the second owner so no warranty. I'm very mechanically inclined, is this something I can fix?
#10 adjd1234
adjd1234
  • 3 posts
Posted 02 December 2007 - 03:20 AM
Thanks for all the input guys.
I haven't spilled any water. Heavy rains thats all. Will that do it? The dampness and some water that creeps in? LOTS of carwashes though- the ones where they make you get out of the car. Maybe those guys did some spillage and cleaned it up..I will look into it.
Where do the codes show up? I am NOT getting any codes whatsoever or any ABS failure text at all after that one time. It was JUST that one time about 2 months ago......... sad.gif . I feel so frustrated and stupid........
I mean if the ABS module is a problem, shouldn't I be getting text and codes in my message window????? Wouldn't my brakes squeak or slip or something?? WHAT am I supposed to experience in a true ABS failure?????? HELP!!
The warranty expired in July I'm being told since we bought the car in Sept of 2003- it is technically a 2004 though. The warranty is for 4 yrs or 4K whichever comes 1st is what I know.
