1998 V70 Xc Awd Upgrades
15 replies to this topic
#1 lookforjoe
lookforjoe
  • 9,884 posts
Posted 22 November 2007 - 08:47 PM
Hi
I recently replaced my '92 960 (which had plenty of usable power) with a '98 v70 AWD XC - what a dog!
So, I put in an IPD remapped ECU, which bumps its performance just out of the doggy range.
Looking through this forum, I saw a thread (locked) that mentioned using T5 16T turbo, white injectors & T5 ECU - does this also apply to '98 LPT models?
How do I ascertain what style turbo flange I have, or is that not an issue?
I feel a little stupid for having blown 700bucks on just an ECU that won't work with a bigger turbo & injectors (IPD claims this 406 remapped ECU will not work out if I upgrade the turbo).
Anyone with my specific model who has experience in this type of upgrade?
Got any helpful part numbers?
I'm very familiar with older Volvos - but these FWD/AWD models are beyond my ken ....
1998 V70 XR M66 Quaife 14J PTE6262 BB Built '04 2.3l Block Wiseco Pistons 147mm H-Beams '03 Ported Head EnemY21Cams TurboTuner 710cc Inj, DW300, 3" DP back Dual Magnaflow 14834's Apr 2013 408WHP AWD (@7925rpm) 347WTq(@4400rpm)@18psi LGSpeed Header Custom Intake Manifold 30x12.5x3.5"Treadstone FMIC AP Racing Clutch KU SM Billet Flywheel Kaplhenke CoilOvers
#2 TBM
TBM
  • 3,690 posts
Posted 22 November 2007 - 11:02 PM
Off topic, but are V70 XC AWD low-pressure turbos? One of my friends is looking into getting one, so I was just wondering...
1998 S70 T5M
- Comets - R Bumper - RICA Tune - OBX Turboback - FMIC - EST Intake - HKS SSQV - IPD HD TCV - Koni FSDs - IPD Springs - OMP Strut Bar - AEM UEGO -
Prosport BG & EGT - ABM Projectors - 6000k HID Lows & Fogs - LED Sidemarkers - Custom XC Grille - R Panels - 18T - R Manifold - Short Throw - 2 Baby Seats -
#3 Arbelac
Arbelac
  • 146 posts
Posted 22 November 2007 - 11:08 PM
QUOTE (TBM @ Nov 22 2007, 03:02 PM) <{POST_SNAPBACK}>
I believe all the V70XC models are LPTs until the P2 versions were available, which made the HPT an option.
Blue 98 V70XC AWD, B5254T, 230,000KM
Black 01 V70T5 FWD, Manual 5 Speed, 206,000KM, QBM Strut Brace Conversion, QBM Poly Transmission Mount, Tom's HD Endlinks
#4 TBM
TBM
  • 3,690 posts
Posted 22 November 2007 - 11:10 PM
QUOTE (Arbelac @ Nov 22 2007, 06:08 PM) <{POST_SNAPBACK}>
For real? The one my friend's looking into is a '98, so I guess it's an LPT.
1998 S70 T5M
#5 Wagoneer855
Wagoneer855
  • 3,186 posts
Posted 22 November 2007 - 11:15 PM
No....
'98-'00 XC70s were 2.4L LPTs (same as a V70 GLT)
P2 XC70s were 2.4L for the first year and a half and then 2.5L LPTs with 208hp and 236ft/lbs.tq
'97 855 - Build in progress
#6 Big Will
Big Will
  • 2,376 posts
Posted 23 November 2007 - 02:16 AM
I'm surprised you think the 98 V70 AWD is a dog in stock form. You might want to check to make sure you don't have a boost leak somewhere.
You can put a straight flange 15G or 16T turbo (very similar) on your car. You do need to be careful about the angle gear (AWD system) as it is very sensitive. If you are doing all of these performance upgrades you definitely want to change the angle gear oil inside it. Use 75W-90 weight synthetic gear oil (Volvo has its own) and you will need 1 quart of it (actually .7liters). This is cheap insurance in my mind as a new angle gear costs about $2000.
The IPD tune should work ok with a new turbo but I have never tried it. It has put your boost levels up to about where the R is stock (which came with a 16T turbo in 98). IPD certainly will know more if you have a chat with them on the phone. You can always ask them to reflash it to utilize the bigger turbo for $$.
Definitely put a bigger exhaust on the car to help it breathe, and consider a downpipe upgrade from CJ or IPD or EST or get a custom one made. The additional breathing will help the car a lot. You can also put the S60R exhaust manifold on your car. It all depends on how crazy you want to get/how much money you want to spend.
Don't forget to upgrade your brakes and suspension if you make the car a lot faster! Safety first.
Flush that transmission and change the Angle gear oil - cheap insurance for sure.
Good luck with those upgrades.
Me: "Yea."
98 V70 AWD Manual: Wothrline ECU, angled 15G turbo, White injectors, EST Intake, R Manifold, TME Downpipe, TME Exhaust, IPD Swaybars + HD endlinks, Volvo Strut Brace, Öhlins Roadholding Suspension + Springs, 302mm Front Rotors and Vented R Rears, SS Brake lines, E-spec C70 Jewels.
2000 V70 XC SE Manual: SOLD
#7 lookforjoe
lookforjoe
  • 9,884 posts
Posted 23 November 2007 - 02:39 AM
QUOTE (Big Will @ Nov 23 2007, 02:16 AM) <{POST_SNAPBACK}>
Thanks for the response.
I've already had to replace the angle drive,it was bad when I bought the car, but I haven't flushed the tranny yet, so I'll do that next.
The car was totally flat in the ranges indicated on the ipd website ECU upgrade - so I was assuming that it's poor performance was par for the course - all the Volvo dealer fellas pretty much felt the same way about it. The car does not exhibit any fault codes that may arise from vacuum leaks, and if there were a pressure-side leak, wouldn't that actually produce more boost, or does the newer system automatically back of timing/etc., in such an instance? The car doesn't exhibit the kind of behavior I've had with 200/700's with bad main turbo feed/output plumbing, so I don't think there's a problem there, but I'll check all the plumbing to be safe.
I'll start looking around for a 16T turbo and a better exhaust manifold.
To be honest, I don't want to spend crazy money on this car, I like it, but I'm certainly not in love with it. I've been driving 700/900's for the past 20 years, I just wanted something that handled a little better/felt different.
I've put the Volvo 17" R rims with 235/45ZR17 Pirellis on it (barely clears the trailing arms!!) so I've got clearance for larger brakes - which I will have to do.
Not sure what to do about the exhaust - IPD doesn't offer anything for the AWD's - and I'm not sure I want to spend so much on that. I guess I'll do the turbo/injectors and see how it plays out.
#8 FastWagon95
FastWagon95
  • 1,423 posts
Posted 23 November 2007 - 03:12 AM
QUOTE (lookforjoe @ Nov 22 2007, 09:39 PM) <{POST_SNAPBACK}>
Check out www.eurosporttuning.com they used to have a AWD cat-back exhaust for your car..check it out.
'95 855 T5M Shaved is better
#9 FastWagon95
FastWagon95
  • 1,423 posts
Posted 23 November 2007 - 03:15 AM
Yep heres the catback: http://www.eurosport..._Code=VL-S70-en
and a downpipe: http://www.eurosport..._Code=VL-S70-en
Cj on this site also makes a full 3" downpipe for the AWD models, extremely nice quality.
#10 lookforjoe
lookforjoe
  • 9,884 posts
Posted 23 November 2007 - 03:19 AM
QUOTE (FastWagon95 @ Nov 23 2007, 03:12 AM) <{POST_SNAPBACK}>
Thanks, FW95 - looks like just the ticket!!...
..I'd bought Euro lights from them years ago for my 960 - very nice people to deal with!
Edited by lookforjoe, 23 November 2007 - 03:57 AM.
#11 lookforjoe
lookforjoe
  • 9,884 posts
Posted 23 November 2007 - 03:33 AM
QUOTE (FastWagon95 @ Nov 23 2007, 03:15 AM) <{POST_SNAPBACK}>
Thanks!
I've ordered the cat-back section - I'll see how that works out first..
..That's quite a wagon you've put together - very nice work!
#12 Big Will
Big Will
  • 2,376 posts
Posted 23 November 2007 - 04:20 AM
Well, part of the reason for the sluggish performance is the AWD. It saps a good amount of the power to the wheels. I am still using my 13G stock turbo and I think with the things I've done to the car you would not find mine sluggish...that said it is certainly different from the RWD Volvos.
Eurosport makes great stuff. If you have 17 inch wheels, you can move up from 280mm rotors to 302s. Slotted or drilled whatever you like. That'll be a good start without a great expense. The part numbers for the larger brackets and what not are listed on this site in the pinned threads. Volvo has 302mm rotors available as does Eurosport and IPD and probably George at Viva Performance (another good resource).
Glad to hear you have a new angle gear. Change out that fluid every 30K miles or so for insurance.
You can find a used S60R manifold at Erie Vovo or other Volvo junkyards vandsautodismantlers.com as well. If you do go for the 16T turbo it is probably wise to get the ECU re-tuned for it to ensure that you utilize the turbo properly given your stock injectors etc. (which from pretty extensive talks with a Volvo mechanic should be good for the kind of power both you and I are trying to make with our wagons).
Me: "Yea."
#13 lookforjoe
lookforjoe
  • 9,884 posts
Posted 24 November 2007 - 04:43 AM
QUOTE (Big Will @ Nov 23 2007, 04:20 AM) <{POST_SNAPBACK}>
I guess I'm exaggerating a little - it's just that compared to the pull of the 6 cyl, and with the AWD - it does feel lacking in the torque dept...
I'll get those bracket #'s -I did the same type of thing with my old '85 740T - put the oversize brakes made quite a difference!
Thanks, Bill.
Just to clarify, you're saying the stock injectors will still be OK in conjunction with a larger turbo? Is the manifold required with a larger turbo, or will it still breathe OK using the stock manifold?
#14 Big Will
Big Will
  • 2,376 posts
Posted 24 November 2007 - 05:21 AM
Good question! You are getting into un-chartered water here for me. I am pretty confident that with correct tuning, the stock injectors will be just fine.
The "R" manifold is gravy. I don't have one on my car (nor do I have an upgraded downpipe), but I think getting a 3 inch downpipe will free up some horsepower. Remember, the 16T isn't exactly a BIG turbo, but in Volvo speak it was the High pressure turbo option used in 98 on the T5/R cars.
To play devil's advocate a bit, the T5 and R cars had different injectors than the plain AWD...
Just for experimenting, why don't you see what the car is like with a freed up exhaust and downpipe. See how you like it. If it is still sluggish adjust the wastegate to the top of the factory spec. There is a range like 1.5-3 psi or something like that...make sure yours is at the top end of that.
The beauty of these upgrades is that you won't need to re-tune your IPD ECU. If it's still too slow after all that then maybe a 15G or 16T turbo and re-tuning to take full advantage. This way you aren't throwing money in all at once, and you can see results (or not) after each upgrade.
Hope that helped.
--Will
Me: "Yea."
#15 XFORCE
XFORCE
  • 75 posts
Posted 25 November 2007 - 03:57 AM
I did a custom dual exhaust on mine, and a ecu upgrade. I didnt feel real horsepower gains, but the torque was rediculous smile.gif it effected my gas milage
2000 Volvo V70XC Cross country (Now Crashed)
Speedtuning ECU
Dual exhaust
6000k HID low beam and fogs
Pioneer AVic Z1 System
#16 lookforjoe
lookforjoe
  • 9,884 posts
Posted 28 November 2007 - 03:00 AM
QUOTE (Big Will @ Nov 24 2007, 05:21 AM) <{POST_SNAPBACK}>
Hope that helped.
--Will
Thanks, Will.
The exhaust is due in January, so in the meantime I'm going to just check the wastegate setting.
Thanks for all your feedback.
