Advice Please
9 replies to this topic
#1 Bracer
Bracer
  • 132 posts
Posted 07 September 2004 - 10:59 AM
Right guys here's the situation.
But now I want to upgrade the stock speaker. At pressent all I have are the ones in the dash, front doors and rear doors with none on the shelf.
(P.S. mine is a 850 Saloon)
I belive the correct size for the front and rear door to be 5 1/4" so I was looking at these 2 options
1) ALPINE SXE-1750S
2) ALPINE SXE-1350S
I was also thinking of some on the rear shelf but as yet haven't measured what the hole size is but at a guess either 5 1/4" or 6 1/2"
So the options are as follows
1) ALPINE SXE-1325S
2) ALPINE SXE-1725S
What ones should I get the specs are pretty close and so are the prices.
SAM ECU @ 29 Psi Mapped For 97 Ron
Custom 2.5" Cat-Back With 4" Tip
TurboXS BOV Type R-HFL
ReliaBoost II MBC @ 0.95 Bar
W/G Actuator Shortened 8mm
BMC F1 Air Filter
Cold Intake System
87 Deg Stat
Relocated Horns
I/C Water Spray +
Ctr Supp. Removed
MAF Srn Removed
Poly Eng Bush
Lowered 2”
Titans
SAM's CarDomain http://www.cardomain.com/memberpage/639353
Volvo's UK Forum http://www.volvot5.co.uk/forums/index.php?
#2 Bing_0
Bing_0
    Sure, I can install that there!
  • 2,155 posts
Posted 07 September 2004 - 12:55 PM
if you are running of deck power, then i wouldnt really worry about it, the main limiting factor to your sound system will be the output of hte headunit, instead of hte speakres, just pick which ever one is hte cheaper one wink.gif
b
#3 Bracer
Bracer
  • 132 posts
Posted 07 September 2004 - 01:00 PM
QUOTE(bing_0 @ Sep 7 2004, 06:55 AM)
b
Quick spec list
CD/MP3 Player with RDS Radio
4 x 60W High Power Output
MP3 File Playback
Ai-Net Compatible
Detachable Front Panel
CD Changer Control
CD Text
3 x 4V Preouts for connection of External Amplifiers (Front
Rear & Sub)
BBE
Bass Engine Plus
Rotary Control
Versatile Link
Remote Control Ready
Telephone Mute
Switchable Illumination (Green/Amber)
Just installed it, sound brilliant even through the stock speakers.
BMC F1 Air Filter
Cold Intake System
87 Deg Stat
Relocated Horns
I/C Water Spray +
Ctr Supp. Removed
MAF Srn Removed
Poly Eng Bush
Lowered 2”
Titans
#4 Bracer
Bracer
  • 132 posts
Posted 07 September 2004 - 01:05 PM
Speaker Spec
1) ALPINE SXE-1750S
5-1/4"(13cm) Component 2-Way Speaker, Peak Power 280W, RMS Power 45W, Frequency Response: 60Hz-20kHz, Sensitivity: 90dB/W/m, Ferrite Magnet, Long Fibre Natural Pulp Cone, Neodymium Magnet, Mylar-Titanium Balanced Dome Tweeter, High Polymer Foam Edge
2) ALPINE SXE-1350S
5-1/4"(13cm) Component 2-Way Speaker, Peak Power 250W, RMS Power 40W, Frequency Response: 60Hz-20kHz, Sensitivity: 90dB/W/m, Ferrite Magnet, Long Fibre Natural Pulp Cone, Neodymium Magnet, Mylar-Titanium Balanced Dome Tweeter, High Polymer Foam Edge
1) ALPINE SXE-1325S
5-1/4"(13cm) Coaxial 2-Way Speaker, Peak Power 200W, RMS Power 35W, Frequency Response: 70Hz-20kHz, Sensitivity: 92dB/W/m, Ferrite Magnet, Long Fibre Natural Pulp Cone, Neodymium Magnet, Mylar-Titanium Balanced Dome Tweeter, High Polymer Foam Edge
2) ALPINE SXE-1725S
6-1/2"(16.5cm DIN) Coaxial 2-Way Speaker, Peak Power 220W, RMS Power 40W, Frequency Response: 60Hz-20kHz, Sensitivity: 92dB/W/m, Ferrite Magnet, Long Fibre Natural Pulp Cone, Neodymium Magnet, Mylar-Titanium Balanced Dome Tweeter, High Polymer Foam Edge
BMC F1 Air Filter
Cold Intake System
87 Deg Stat
Relocated Horns
I/C Water Spray +
Ctr Supp. Removed
MAF Srn Removed
Poly Eng Bush
Lowered 2”
Titans
#5 Bracer
Bracer
  • 132 posts
Posted 07 September 2004 - 01:08 PM
Also am I right on the size for the rear shelf ?
As for the price there the same so its the spec / fitment which will decide, will it not matter that one has a full mounting ring and the other has protruding fixing points, dont really want to start cutting things about wink.gif
BMC F1 Air Filter
Cold Intake System
87 Deg Stat
Relocated Horns
I/C Water Spray +
Ctr Supp. Removed
MAF Srn Removed
Poly Eng Bush
Lowered 2”
Titans
#6 Bing_0
Bing_0
  • 2,155 posts
Posted 07 September 2004 - 01:15 PM
well, if prices are the same, then go with the comp sets, but like i say, your main limiting factor is going to be the amount of clean power hte alpine headunit puts out, rather thant he speakres themselves, i have installed and/or worked with all the components you have listed smile.gif
our 850s fit 5.25s front and rear doors, and 6x9s rear deck, BUT, they dont fit just ANY such sizes, usually one that is not to deep will fit better, so its hard to say if the speakres you listed will work in our cars with out and modifications...smile.gif
b
#7 steve s
steve s
  • PipPipPipPip
  • 3,254 posts
Posted 11 September 2004 - 08:39 AM
even for the same set of speakers, it may fit on one 850 and not another 850
#8 Veneficus
Veneficus
    biggie
  • 6,066 posts
Posted 11 September 2004 - 01:25 PM
Just to add to what will fit, larger 6x9s will not fit into the back deck. For example I have some Infinity Kappas that I got that will not fit no matter how hard I try to get them into there. I've heard that you can retrofit the stock black speaker boxes to fit the midline 5x7s into.
- Captain John Paul Jones
#9 Guest_UnsanePyro_*
Guest_UnsanePyro_*
Posted 13 September 2004 - 09:12 PM
I have some pioneer speakers, 6x9s, fitted into the black speaker boxes on my 850. They are for sale too smile.gif
#10 550
550
    someone please talk to me
  • 10,275 posts
Posted 13 September 2004 - 11:37 PM
How much unsane??
