The DIY RIP kit for now,
Hi Johann,as I saw you made a custom hose-piping for the idle valve also,does the diameter of the used parts,has to do with the behaviour of the car at idle?
This setup was made to fit the Supercharger plumbing when it was first used without the intercooler.
Later on it turned out to also fit the intercooler setup. With the change to turbo this part of the plumbing remained the same. Diameter didn't change much though.
I assume that diameter will affect idle behavior if the idle valve runs out of range.
I'm using a standalone ECU and need to set the idle valve behavior using the provided software.
OK,thanks,will you go for a dyno run after everyhting will be finished?
Saw the car 20th of march at my software day at Fasttech's place!
Thanks for he short drive-around Johann!
The sounds was really impressive and the craftsmenship of high level! B)
The car smell at the inside was in nicotine-terms also very good! :P
I must have missed this topic a lot....in the previous pages I saw the red 850 with GT3071 on,now here I see a red 850 with a supercharger!!!!
First it was supercharged, now there is a big turbo on it. <_< B)
for some reason i thought you were compound charging this red car.... :unsure:
It has been an idea but I didn't see any advantage of such a complicated setup.
