volvo740wgn
S90 Error Codes
My 1998, S90 failed Mass. inspection because my check engine light was on. Because the check engine light was on it failed emissions. The two error codes that came up during diagnosis were, P0112 and P0116.
P0112 -Intake Air Temperature circuit low input
P0116 -Engine Coolant Temperature circuit range/performance problem
A sensor from radiator is broken and I think that could be causing one of the errors. I believe the only way to repair that is to buy on new radiator. Not sure which error is it though.
Anyone know what can cause these errors or where the problem is located?
They both probably mean the sensors are bad. I doubt you need a new radiator.
You need a t-stat and an IAT sensor(cts sensor,whatever you want to call it) good luck getting the monitors up and ready!
