Looking For Better Sound In My 850:
Posted 19 September 2004 - 05:36 AM
First, I am interested in redoing all of the audio in my car. I want to buy a new HU, at least new front speakers, but possibly rear speakers, a subwoofer and a 4 channel amplifier to power the sub and two speakers.
I went to The Good Guys tonight and listened to some speakers. They all sounded horrible to my ears, very bright and unbalanced. I am open to the idea that it is because they were all mounted on a wall instead of in a car, but I just have no way of telling what is good and not... it is out of the usual context of audio equipment I am used to.
My first question: How do I choose a pair of speakers if none of them sound good to me? I actually think my stock speakers sound better than any that I listened to, but I am positive that an aftermarket pair are constructed much better.
One of my rear speakers is blown out. I am not quite sure how it happened, but it is no longer functioning. Now I have heard several varying opinions about the option of rear speakers. I am not sure if I should just forget about the rear speakers and focus on the front speakers, or if I should buy a pair for the rear as well.
Second question: How should I choose a pair of rear speakers?
This leads to my next question. I want to buy an amplifier for the system. I would like to buy a 4 channel amplifier and power a subwoofer and a pair of speakers in the car, and if I buy rear speakers, leave one set of speakers to the amp and one to the HU.
Which speakers should I let the amp power?
It is so hard to buy something like car speakers when the only way you can listen to them is so far out of context.
Another question that I forgot...
Since the front speakers are a 5 1/4 woofer and a tweeter, should I buy a set of component speakers, or would I fare well with coaxial speakers? If I were to buy a set of component speakers, what would fit in my car? How would I go about powering the tweeters?
However, I also listened to 6.5 inch speakers (actually that is all that I listened to) and they barely had any midbass. I can't imagine that I set of 5.25 in speakers would have any at all. I suppose this is the purpose of rear speakers.
Now lets assume that my system is set up as such: Front speakers for mids and highs, rear for midbass, and a sub for the bass. How do I set up a network of crossovers for the system so that my front speakers are filtered out frequencies below somewhere around 200 hz and my rears at around 90hz and my sub playing everything below around 90? I don't want my front speakers (in particular) working to produce frequencies that they simply can't and distorting as a result. I don't want my rear speakers travelling too far into the realm of bass but I don't mind if they go a little lower than midbass either. Is this something that is just standard in most systems, or am I dreaming?
Thank you if you have made it all the way to the bottom of my post. I look forward to reading any replies!
The only upgrade is my stereo.
She said I was living too much in '82.
HU: Alpine CDA 9825
Amplifier: Kicker KX 600.4
Front Stage: Crystal CSX 615 in Kicks (by Bing)
Rear Stage: Nothing.
Subs: 2 Crystal Pro Se 10" subs in a sealed enclosure
Posted 19 September 2004 - 07:04 AM
but i suggest u go to another store to listen for speakers. obviously, wall setups are not gonna sound the same in the car. but, specialty audio stores may have extended lineups or more options from different manufacturers.
the stock speakers are designed to play the full range...bass.midbass.treble. it's ok. but any large amounts of bass tends to cause the speakers to flutter. almost all aftermarket speakers will not do that. keep in mind that most aftermarket speakers are designed to play mid-bass and treble. they don't produce a lot of bass, necessitating an addition of the subwoofer (which u seem like u wanna do anyway).
u could look into component speakers as well. the front setup on the 850 is actually a component set, with the front door the mid-bass/bass and the dash the tweet.
if u think the speakers u've listened to are a bit harsh...u should look into speakers that have tweets that aren't made of metal. silk tweets are very smooth..metal tweets tend to be harsh, like the kappas i got.. if i had a chance to do it all over, i actually may look into the infinity reference components instead.
ur front door speakers will fit 5.25"..altho on some cars with some speakers, u may need to open up the metal trim behind the speaker.
tweets can go in the spacer provided in the dash, or remove the spacer and put in 3.25" dash speakers if u wish. altho, since u don't like the harshness u heard in the speakers at the store, u may be better off with the components.. 3.25" dash speakers tend to play higher freq better..
Posted 19 September 2004 - 01:49 PM
Posted 19 September 2004 - 04:41 PM
This what I would do.
Boston Acoustic speakers all around, they might be a little pricey but very good quality, I love mine. Then run a 4-6 channel amp to them to boost their power.
As for a sub get like a JL Audio, or even a Boston Acoustic, and their are other brands, but these are I am fond of. And get an amp for it that is reccomended for it.
Your system will sound very good. If you can spend the money on the Boston Acoustic component sets do so, they are extremely nice.
Posted 19 September 2004 - 04:49 PM
Posted 20 September 2004 - 01:05 AM
Some other good brands are Infinity, although I don't like them. etc...
Posted 20 September 2004 - 03:23 AM
as for choosing speakres that dont sound good, well, keep on sampling them and definetly try to sample them in the car, if you think speakres sounds harsh on the sound board, they will sound even more harsh in your car...
but it seems you are basicalyl looking for a moderate system, so perhaps taking some advice form others and just go ahead and try out a set up may be good enough...
b
Fully authorized Dealer: Image Dynamics - DLS - Elemental Designs
Posted 20 September 2004 - 05:39 AM
Anyway, back to my homework.
HU: Alpine CDA 9825
Posted 20 September 2004 - 05:40 AM
b
Posted 20 September 2004 - 05:41 AM
I emailed this message to Crutchfield, and they told me the doors can only accomodate 4 inch speakers and didn't answer many of my questions. They just told me exactly what to buy, which I am sure has much more to do with profit margin than sound quality.
Edited by The Reverend, 20 September 2004 - 05:41 AM.
HU: Alpine CDA 9825
Posted 20 September 2004 - 05:45 AM
but anyway, if you are really serious ab out getting good sound quality in your volvo, PM me, i can help you design a system out
or find me on msn at bing_0@hotmail.com
b
Posted 20 September 2004 - 05:48 AM
4" Alpine Speakers for the rear??? I thought the rear was 6x9 and the doors were 5.25... this guy doesn't know the car.
Kenwood Weak Amp
My Personal favorite:
THIS is the sub he recommended.
That is just about the worst system I could imagine.
HU: Alpine CDA 9825
Posted 20 September 2004 - 05:52 AM
b
#14
Posted 20 September 2004 - 06:20 AM
crutchfield will give u what they know will definitely fit.
that said...u could fit 5.25" in both doors...just donno, for ur particular car, if the front speaker magnets will hit the door, or if the rear speakers will fit under the stock grill
#15
Posted 20 September 2004 - 06:24 AM
b
#16
Posted 22 September 2004 - 05:30 PM
i have infinity kappas all around and i must say that im not impressed with them one bit. your better off with JL or BA. i would invest in a pair of kick pods because the door locations can't handle much bass (or maybe it's just my car).
2004 Volvo V70 2.5T Titanium Edition
