  • entry
    1
  • comments
    2
  • views
    5,031
1999 S80 T6 Heater Core Problems?
DOC NGC
So I have a 1999 S80 T6 and everything is great, except the Heater Core is leaking! I found it but I cant find any way to get it out. Does anyone know how I can go about doing this? After taking apart the passanger space and seeing the little leak I still could not see how it can come out. So if any one knows I can please send any and all info I would much appreciate it. Try to respond to this blog and if no luck then try my e-mail, thanks
acarsey@gmail.com
2 Comments
Recommended Comments
its tricky but can be done. disconnect the lines on the engine side of the firewall.drain all the coolant...remove the lower trims on both sides of centre console and peel carpet back...some torx screws await you so get them out carefully...its a tight fit but the core can be pulled out the passenger side...have lots of rags or towels ready tho for the exra coolant that comes out of the lines....
  • Upvote 1
Guest
Add a comment...
  Only 75 emoji are allowed.
