  • entries
    42
  • comments
    0
  • views
    5,959
Mar 26, 2006
Checking in... no I haven't been goofin' off.
I've gotten the interior about 90% buttoned up... except for the pieces that I broke here and there. :angry:
I did get CJ's ventilated block bolted up to the M66 and dropped into the bay so that I could figure out the cables, etc. WOW! - This sure is a shiney motor mount!!!
Yesterday I was a bit under the weather thanks to Mr. Merlot. But I did get most of the interior back in play. Just need to tie up a few things here and there.
Today - I went to work on the engine bay. Time to get clean in prep for the engine.... hopefully :blink:
So boys and girls.... if you are going to clean your engine bay, this is the only right way to go!!!!
OK - after a good degreasing and scrubbing... I carefully applied paint code 601 in all the right spots.
When you paint... masking is the most important thing. Look at that!!!!
Somewhat put together again at the end of the day.
Now I need to modify the wire harness assembly for the Manual trans. So many things... so little time!!!
Ciao
Scott C.
0 Comments
Recommended Comments
Guest
Add a comment...
  Only 75 emoji are allowed.
