SuGeRBLacK
  • entries
    5
  • comments
    0
  • views
    6,626
Pulling & Clearing Codes + Other Issues
as a follow up to the last entry - the electrical portion of the ignition switch didn't solve my instrument panel light problem. Went to dealer to get a new rheostat switch . . . $177!! as i had it out i dropped it too, breaking the slider like a knucklehead. I won one on ebay for 8 dollars, but i am suspicious that when it comes it won't fix the problem.
I did the cabin filter last weekend & ended up having the fuel filter done & seat back cable w/ an oil change. Really didn't need to do the seat back cable but hey.
this week the wife filled the tank and parked in front of the house (we live on a hill). i noticed fuel leak the next morning, seems like the same problems as the threads here w/ fuel tank leaks @ the top of the tank so i need to take a good look to see if i need to replace that hose. Its tooo damn cold out right now though.
I did manager to get out there and pull & clear my codes so here they are recorded.
#A1 - transmission: --- 2, 3, 2 (missing spedometer signal) i believe this is old, previous owner pulled the instrument cluster out to replace lights.
#A2 - engine: --- 2, 3, 2 (long term fuel trim @ idle) & 1, 2, 1 (missing or faulty MAF signal)
#A3 - ABS: ---- 2, 1, 3 (no left rear signal on moving: off) & 2, 1, 4 (no right rear signal on moving: off)
so i'll give it a bit of time & see which come back, may only be the A2 codes.
Have a couple of other issues though that still need to be addressed besides the instrument lights & the fuel tank leak. Still need to solve the scrapping sound in the engine, sounds very much like it is coming from the alternator. I checked the power steering fluid and it is not low. Also, i am still getting a lot of blue smoke @ startup and am going to need to address this as well. I have had to put a bit of coolent into it recently so that may not be a good sign, though i'll keep researching on volvo speed for that issue - flame trap?
i also still need to set by boost controller, so i don't bend any bars.
0 Comments
Recommended Comments
Guest
Add a comment...
  Only 75 emoji are allowed.
