  • entry
    1
  • comments
    4
  • views
    6,125
850 Turbo No Start
Got in the 850t thursday, drove it 5 miles and parked it. Got in 2 hours later, and no start.
5 days later still no start. When i first tried, it caught for just a second, wouldn't accelerate, then died. No start since. Ive checked the ignition module connector and ground. ive pulled the fuel pump relay and replaced it. I pulled the fuel pump and it comes on when the key is turned. I'm lost. Some one give me some direction
4 Comments
Recommended Comments
Immaquitter
possibly check the connection plug to the pump, or then the pump itself..your battery voltage could also be low. these cars draw a lot of power when starting...they should have a battery rating of at least 600 cca...let me know how you go with it
wlo2000
I have the same exact issue with my standard 850. So please tell me what you find out!!
NcTrooper10722001
Injector Relay.. If you have have Spark @ the plugs and the fuel pump is running, then No injector pulse .. check into it
Will649
Is it crank no start issue or crank but no start issue?
Guest
Add a comment...
  Only 75 emoji are allowed.
