  • entry
    1
  • comment
    1
  • views
    5,079
National Car Care Month
Wipers123
April is National Car Care Month and I encourage everyone to take a walk around their vehicle and take a look at the common maintenance areas, many of which are quick, do-it-yourself (DIY) automotive maintenance items.
1. Tires: Check tire pressure, check treadwear, is it time for a rotation? Your correct tire pressures are listed right on the tires and on a sticker inside your driver door.
2. Bulbs: Check for any burnt-out bulbs - especially center/high brake lights (which seems to be an epidemic in the USA).
3. Fluids: Check all fluids under the hood. Most reservoirs have clear markings. Also check your oil change sticker to see if you're due.
4. Air Filters: Check your engine air filter and your cabin air filter. Replace if necessary. Yes - many vehicles have TWO filters which should be changed every 6-12 months depending on your driving habits and climate.
5. Windshield Wiper Blades: Inspect and replace your windshield wiper blades taking note that most should be replaced every 6-12 months.
Depending on your automotive maintenance skill level, there may be other things you should inspect/check/replace.
National Car Care Month serves as a reminder that vehicle maintenance leads to safer vehicles and safer roads as well as a more satisfying driving experience. Use this as a reminder to take a few minutes with your vehicle!
Jeff
President
Wipers123.com
Good Luck!!
1 Comment
Recommended Comments
Keeping your car in proper maintenance is critical for keeping yourself and your family safe.
We specialized in wiper blades replacement. You have to be able to see in rain and snow. So keep your wipers in proper order. Please replace them every 12-18 months. We are all about making it easy to find, purchase, and replacing your own wipers and keeping good quality Trico wipers affordably on your car.
https://www.wiperbladesusa.com
Guest
Add a comment...
  Only 75 emoji are allowed.
