Again, thanks for the information. I haven't started mine yet because when I read your writeup and saw the torque values for the strut bolts I realized they were TTY bolts and I needed to get new ones. They are currently on order from IPD, along with new strut mounts/bearings (yet another might-as-well-as-long-as-I'm-in-there). As I said above, I decided to get new ones. They are torque-to-yield bolts, as signified by the additional turn amount after the torque value is reached. From Wikipedia: Torque to yield fasteners are mounting hardware which is torqued beyond the state of elasticity and therefore undergoes plastic transformation, causing it to become permanently elongated. Torque to yield (TTY) bolts are often used on cylinder heads in modern combustion engines for the sake of saving weight and to obtain a more precise clamping load. Compared to normally tightened hardware, a smaller sized TTY bolt/screw may be used while still maintaining the same clamping force. A drawback with TTY hardware is that it normally has to be replaced when loosened, for example when the cylinder head is removed. Since you didn't go wild when tightening them back they may be OK. It seems as though most of the load would be 90º to the bolt axis and not much, if any, along its axis (as there would be with a head bolt clamping the head to the block). If you wanted to replace them you could do them one at a time and not alter your camber. You should be able to get Grade 8 (or better) bolts from the hardware store - they aren't anything special, they just need to be the correct length and diameter.
