Anybody got a used flywheel/clutch assembly off a late model T5/R they could give me measurements off?
I typically frequent Turbobricks since I have a 760, but it's swapped to a 2.5t 5 cylinder so I thought I might have more luck here. Project thread if you're interested:
https://www.turbobricks.com/index.php?threads/760-5-cylinder-scratching-a-10-year-itch.341191/
I'm running a bmw 6 speed trans, with a 850 single mass flywheel. I daily this car and I'm over the gear noise and want to swap to a dual mass, but the input shaft is quite short on the GS6-37 transmissions which are designed for a pilot bearing in the flywheel. Anyways, trying to find the height of an assembly flywheel/clutch/pressure plate assembly to the surface of the pressure plate fingers to see if this is even an option for me. Can anyone help me out?
Thanks!
