Frank Derks
Vendor
  • Posts
    345
  • Joined
  • Last visited
1 Follower
About Frank Derks
Previous Fields
  • Location
    Burlington, Ontario
Recent Profile Visitors
The recent visitors block is disabled and is not being shown to other users.
Frank Derks's Achievements
Newbie (1/14)
43
Reputation
  1. There are just a few days left and we only have a couple kits left!!
  2. Not likely, if you are interested in purchase just the hardware kit I would suggest that you act soon as we only have a few of them left!
  3. This deal is on until the end of this month. We do not sell the lines seperately they only come with our hardware kit or the complete big brake kit.
  4. Big Brake Hardware Kits For those of you that always wanted big brakes on your Volvo (850/S70/C70 or V70 up to 2000) and never thought that you could afford them now is your chance as we are offering a hardware kit that includes all of the custom parts which you need to put together your own kit for a limited time. The hardware kit contains: 2 Mounting Brackets for 911 (993 body style) Porsche Caliper - powder coated black 4 Mounting Bolts 2 Stainless steel braided brake lines with fittings 1 can ATE Super Blue brake Fluid Complete kit $335 USD plus shipping - Offer valid until Oct 31 while quanities last!! What you will need: - Porsche 911 (993 body style) calipers, both Turbo (AKA Big Reds) and none Turbo calipers will work with our brackets but you must specify which calipers you will be using when ordering our kit. You can find good used calipers on www.ebay.com or check out www.laporsche.com. A good used set of calipers usually go for $500 USD - S60R 330mm front rotors. We have Volvo original rotors available for $130 USD each or we also have cross drilled or slotted one piece rotors available on our website $197.95ea USD or our 2 piece rotors available in cross driller or slotted $749.90 a pair. BOUNS OFFER - purchase our hardware kit and 2 piece rotors and we will discount the rotors to $675 USD for the pair!!! - Porsche 911 (993 body style) front pads. We can supply you with pads as well, depending on what you want and which calipers you will be using (Turbo or none Turbo) brake pads start at $50 USD for a set. NOTE - you must have 17" or preferably larger wheels to fit the big brakes. You might also require spacers and longer wheel bolts to fit your wheels over the calipers. As I mentioned above this is a limited time offer which ends Oct 31 or while quantities last!!! So order yours today!!! Below is a link where you can place your order: Click Here To Order
