ziddey
Members
  • Posts
    1,240
  • Joined
  • Last visited
About ziddey
  • Birthday 05/08/1986
ziddey's Achievements
Newbie (1/14)
0
Reputation
  1. maybe the spring isnt strong enough for wahtever reason although if the PO of it was able to do 13psi, something seems astray
  2. I remember gregg was a big supporter of better grounding and smoother power and smoother idle. I might give it a go on my beater vw fox. The electronics sure are iffy in that car. edit: I crapped my pants and I love how it feels i meant I'd give newer ground wires a go. not this $200 kit
  3. volvo stock airbox is very efficient already. you won't benefit much from some aftermarket. and most certainly not stock. this is swedish stuff man, not some japanese stuff edit: hahaha i actually wrote "stuff" after swedish. it was the word after japanese that got censored
  4. nice! are you planning on making a plumb to use the stock intake tract as well? You should consider it and having a block off plate, because as stated, water could be a problem. And the plate would allow you to only use the stock tube when you have the top covered as well. So you can sort of switch between the two. Real hot though!! What are we going to see next? A scoop to attract air? :D
