Days Won
15
venderbroeck last won the day on October 15 2021
venderbroeck had the most liked content!
Recent Profile Visitors
12,424 profile views
venderbroeck's Achievements
Hello! I have a volvo c70 2.3T me7. gt2871r turbo, bigger injectors, bigger maf case, and many other. Can you help me tune it? Waiting for your answer. Thank you!
cedricvanroeyen started following venderbroeck
Beste Maarten,
Ik ben binnenkort eigenaar van een 2003 v70r en zou graag zelf de ecu willen mappen. Kan u mij hierbij helpen?
Met Vriendelijke Groeten,
Cedric Van Roeyen
Soo it's been quite a while. As I've already sent to a lot of people, I had to get away from the forums and other volvo related stuff to finish graduating. I'm back again though, so time to catch up again. My engine build has progressed a tiny bit, but not much. I've been looking around for some valve buckets. The valve lash had become too small, as I had ground the seats for the three angle valve job. Those buckets are ~18 euro a piece, and I needed 13 new ones :P After looking around some I had found a webpage online where someone described machining the buckets to size. My uncle is a machinist, and fortunately he agreed to machine the buckets for me. So lucky break there, saving me a lot of money. When I get those back the engine is ready to be put together the rest of the way. I have all the parts needed on hand. Apart from that I've been busy cooking up a BBK to got with my increased power. I will explain it in a little more detail when my engine build thread gets de-archived (mods? :) ). I'm now in the process of getting back to everybody who has sent me a message the past few months. Feel free to ping me though.
With normal gasket, I mean a paper gasket which was originally used on this block. The mls gaskets need a specific finish on both the block and the head. I have seen some of them fail despite having this specific finish done by an experienced machinist. They are probably stronger than the paper gaskets if they are installed correctly, but as I wont run into the limits of the paper gasket it's not worth the trouble for me. The standard gasket (for my block) will suit me just fine :)
Just a normal headgasket. I don't see a reason to swith to the mls gasked, as I'm not aiming for 400+ hp. The open diff, and the local crowded road network would make that a pointless exercise. It also requires a perfectly flat/true deck, and can fail if it is not. I will be measuring the deflection of the head with a special straight steel stock and some feeler gauges. I don't expect it to be bent though, as the engine hasn't overheated, and the gasket that came off it was in good condition. I read the guide on cc polishing here on VS (among many others) which also mentions this. I tried to smooth the meat around the spark plug best I could, but I didn't want to remove too much material, and lower compression more than necessary. For detonation suppression, I don't think they don't play a huge role due to their proximity to the spark plug. Stock seat on the right yes. The lowest angle is uneven on all the ports. This is not a huge problem as there is no contact with the valves there. For flow it might matter a little, but I don't see an easy way to correct it. The valve seat inserts don't seem to be perfectly perpendicular to the valves themselves. So none of the ground surfaces are even (although they are perpendicular ofc). For the contact area width measurements I used the smallest width on the seats.
I believe they are, but I'd have to ask. They are not mine. This is actually the first time I do this. My dad has done the same thing on his head though (the tools are his), so I have seen it done before. I like the low speed cutters, as they are quite controllable. These seats are hardened, so I want to remove as little material as possible. Also because of the solid lifters ofc. I expect the exhaust valves will need the same work, but I gotta clean them up first to see. For the valve lash adjustment I have a little trick up my sleeve which will potentially make things quite a bit easier. I will share it once I work out the details ofc, and describe the process.
Almost, I would need to use metal polish to accomplish that, but that is going way overboard :p Right now they are oily / greasy so not quite so shiny. Both the pistons and the block where heated. We have good experience with this machinist, so I trust his judgement. I used the correctly colored bearings using the markings on the block and the crank. It turned out I needed all yellow bearings which was convenient. I didn't plasti gauge them though, but volvo's tolerances are generally quite good. About the valve job, it's funny that you should ask. Today I finished the 3 angle valve job on the intake valve seats. The process went a bit like this: First I inserted a (slightly oiled) guide pin in the valve guide: A cutter can then be slid over the guide pin, which centers it on the seat. Also notice that the cutting bits of this 15 degree cutter are adjusted such that they exactly reach the top edge of the seat. The other cutters are less critical, but they need to be adjusted so they can reach the surface they need to cut. This is the resulting 60 degree cut marked with the little blue stripe: After that came the 45 degree cut (red stripe). This is the actual contact surface of the valve seat. I put it at 1.5mm at the narrowest point, which is slightly above the minimum spec. And to finish off the 60 deg cut (little green stripe): To the right you can still see the original seat vs the newly ground seat on the left. After this I'll take a good look at the outlet valve seats to see if they need the same treatment. After everything is done I will lap them in, and check if they are leak free. As I have solid lifters I might have to adjust valve lash which is tedious with these heads unfortunately. I'll document my struggles when I get to that as well.
I think they look quite good actually. They are quite subtle, and make the car a bit more unique. The decal has to go indeed :p
I really like how it looks, you did a good job. The red color is starting to grow on me, especially with the dark trim. What did you do with the black headlights btw? I'd be interested if you want to get rid of them ;)
Didn't have a lot of time to work on my engine, but I got some things done. I fitted the remaining 2 pistons, so the engine now has 5 pistons again! ^^ I also noticed a little valve in VIDA which is located in the sump. It has part no 463963. It's in the oil filter area, and its function was quite mysterious to me. After some searching around I found out that it's function is to quickly vent the air from the filter after an oil change. If oil then tries to push through it it has to close up. If it's worn, or if there's any debris stuck in the valve, it could cause to valve to remain open, and bleed oil back into the pan. This results in a loss of oil pressure, which is something I defininately don't want. The advice is to just replace it. It costs about 30 euro. I decided to take it apart to take a look at how it functions though: As you can see, you have to drive out the little pin, after which the plunger and the spring will come out. I inspected the plunger, and the inside of the valve for wear, and it all seemed to be in good condition. After cleaning everything thoroughly, I put it back together and the plunger seems to move smoothely, without any binding. I'm feeling confident that it will function just fine. Just a little bit more info about its operation: You can't close it by blowing through it, as the spring is keeping it open. It only closes if a fluid flows into the valve with sufficient pressure. If the spring were to weaken, it wouldn't result in loss of oil pressure, as the valve would only close easier in that case. If there's debris in your oil, the valve can get stuck open by the debris. Another reason to run good quality oil, and keep an eye on your oil changing frequency. I also removed the old seals from the tube in the sump, and from the oil pickup: The two seals on the right came from the tube in the sump,and they were the same shape at some point in time... The right most one was very loose around the tube, and also quite loose in its seat. I think these may have been responsible for killing this engine. I can't say for sure, as the bigend bearing was already shot when we bought the car it came from. One thing is for sure, these must absolutely be replaced at a rebuild, and maybe even earlier, or they can cause loss of oil pressure. To close off, a shot of the reassembled pan, with the valve installed on the bottom left on top of the oil filter housing:
Haha, more cool volvo electronics are in the works. Later though.. First the results of today's work. :) After asking around a bit, I decided to take off at least one piston ring to check the clearance. Mahle states that the rings have been pre gapped to the correct size so you should be able to install them. Measuring them, they came up fine for the 350-400 hp range I'm shooting for. Then came the time to line everything up to prepare for assembly: I weighed them again, and again 2 of the piston rod assemblies where ~1 gram lighter than the others. I put them in position 2 and 4. To install them, the big end bearing caps have to come off, and that turned out to be a bit of a challenge. After trying to pull them off for a while, to no avail, we had to come up with a different tactic. In the end I put some cloth over the handle of a hammer and inserted it through the big end. Then I screwed the big end bolts in leaving them slightly proud of the hole. After tapping the bolts lightly with a small hammer, the caps came free: You have to make sure you put the caps back on in the same orientation as they came off. Installing them rotated 180 degrees would be disastrous. Luckely the serial number is stamped on the same side on both the cap, and the conrod, so that can be used as a marker. Then we proceeded to install them into the block. I didn't take any photo's of the process, as we were concentrating on not making any mistakes. Especially the first piston took some trying to get it all right. In the end the process was as following: -With the block upright, put the crank at bdc. -Clean bearing races of the big end very thouroughly -Use oil to lubricate the piston, the bore, and the piston ring tool. Also wet the piston rings with oil. -Put piston into tool, and tighten the tool until the piston rings are compressed enough to fit in the bore. -Make sure the tool is square, and put it on top of the bore. -Make sure the piston is oriented correctly, with the arrow pointing to the timing belt side of the engine. -Use wooden handle of a hammer to gently tap the piston into the bore -Push the piston in far enough so the big end bearing can be installed (rotate crank to make a little more room if required). -Make sure the bearing races, and the backs of both bearings are spotless. -insert the bearing shells. Mine where marked at one side, I made sure that the marks of both the bearings where pointing at the timing belt side of the engine. -lubricate the top bearing shell, and push the conrod into position on the crank, with the crank again at bdc. -lubricate the bottom bearing shell, and insert it into the bearing cap. -place the bearing cap on the crank, completing the big end. Make sure it is oriented correctly with respect to the conrod. -Put some arp assembly grease on both the threads, and the bottom of the head of the arp 2000 bolts. -Screw the bolts in finger tight. -In my case (lacking a stretch meter) torque them down to 55 lb/ft, which is 75 nm. Rinse and repeat. We managed to get 3 pistons in today, the rest will follow later on:
I got the pistons from autoteile-teufel.de (germany). The polishing was done as follows: -120 grit flap wheel in a hand held drill (shaft of flap wheel was too thick for dremel) -150 grit sanding paper for the parts that could not be reached by the flap wheel. Up until here is by far the most work (several evenings). then: -240 grit sanding paper (one more evening of work) -320 grit wet sanding paper (using water) -400 grit wet sanding paper (using water) -600 grit wet sanding paper (using water) The 3 higher grits where done in one evening. Is it worth it? I don't know yet. I'm happy with it though, and I don't regret doing it. I will not be balancing the whole assembly. My dad has done it this way before without any issues. The flywheel itself will be balanced by the machine shop. I am not planning to run it at very high rpm. I will run the engine in my 850 using a heavily modified m44 ecu. I'll be controlling the vvt using m44 as well. Ill post about my modifications when I get around to coding them in. Bore to piston tolerance is 0.02 mm, as recommended by mahle. The machine shop said they where quite tight in the bores, until he heated the block to 60 degrees centigrade. Then the tolerance was a little wider.
As requested by several people, I will keep a build log of my engine here. There's a few things I plan on doing with this, some of which will be revealed later It all started a few years ago when I decided I wanted to do a very quick build on the original engine of my '94 onyx green volvo 850 t5. The plan was to just fit some h-beam rods, and new big end bearings. Some time later the plan evolved into using the rods to build the broken RN engine that came out of our '00 c70 which had a missing big end bearing. I picked up the idea to hone the cylinders, and fit new piston rings as well. I think everybody knows where this is going... In the end (after saving, and trading parts for almost 3 years) it turned into a full rebuild. So some specs of the engine then: -rebored '00 bt5234T3 single exhaust vvt engine -OS1 Mahle pistons -cx racing H-beam rods (139,5 mm) -later lighter crank, as the original was shot because of the missing bearing. -All new Volvo bearings -R manifold -clutchnet fiber carbon friction plate combined with a volvo 850r pressure plate. -lightened flywheel I will first swap it in, while keeping the stock hardware for now. Somewhere in spring I will upgrade the turbo to a Holset hx30w, and add some more toys. First I (painstakingly) polished the combustion chambers, and smoothed out some of the casting flash in the intake runners. This was a lot of work, but it's shiny at least, hopefully it will reduce knock susceptibility: Here's a phone pic of the engine block right after the rebore: So after thoroughly cleaning all of the parts, the time came to mount the crank and the main bearings. Here the crank is already in, and I'm rolling on the liquid (well more like chewing gum like) gasket on the intermediate section: Fitting the main bearings shells in the intermediate section: Of course the bearing surfaces where liberally oiled before final assembly. This is how it sits at the moment, the crank is rotating perfectly with no binding or irregularities: Furthermore I attached the cx-racing h-beams to the mahle pistons today: I took the time to weigh both the rods and the pistons before assembling them. The pistons are dead on, and two of the rods where +-1 gram lighter than the others. Negligable differences I would say. I will weigh them again before I mount them to position them in their final order. That's it for now. Tomorrow I have to get the car itself through the Dutch equivalent of annual smog testing. Once that is over with I'm picking up the head from the shop (I had it professionally cleaned), and dropping off the flywheel to be lightened. Saturday I hope to torque down some arp big end bolts.
It is, I've finally got more or less all the parts to build it. :D I'll probably keep a little build log in here, although most ppl here already saw an engine being built ofc :P
Coming soon:
