@tuner4life:
All first generation C70 models (coupé and convertible) have 4 bolt control arms, as do all P80 AWD models (850, S70, V70) and all P80 cars equipped with a diesel engine (850, S70, V70). In those cases the model year does not matter.
What kind of clamps are you using? It almost looks like the normal style with the punched through holes. I'd recommend changing these to smooth-type ones. A lot of the original hose clamps were supplied by ABA and are of the smooth, e.g. no punched through holes, type. They are more expensive but reduce stress in the contact area. They make a few different variants, with rolled over edge, stainless etc. but the original variant with blue top is more or less what was factory. Be careful as to not get fakes as those for some reason do exist.
I'd also recommend rethinking the use of cable ties. Unless you used special ones with rounded edges and a smooth inside they will damage whatever they hold together over time. Vibrations, and as this is a car that's 100% guaranteed, will allow the cable tie to rub and slightly move around. As the cable tie is often made form a harder material, the longer this goes on the more the underlying material gets roughed up. At some point failure happens. Your pictures show slight bending of the fuel filler neck hose so that will be a likely failure point. Btw: That hose is no longer available...
