General Volvo Files
25 files
readme7
By rkam
ME7 reader for the DiCE
Put it in a folder like for example c:\volvo\
Then start a command line window and change directory to that folder.
It can take your DiCE name as argument, or try the typical one if you don't
c:\volvo>readme7 DiCE-203040
It will always read 1024kB, so if your ECU is 512kB you will get same twice.
212 downloads
Submitted
Submitted
850 timing belt R/R
By jefhon
.pdf instructions for replacing the timing belt on the 850. a note: for 1993 (i don't know about other model years) there are actually TWO different size belts depending on serial# & date of production.
111 downloads
Submitted
knock sensor TSB & updated kit replacement
By jefhon
some models "require" an updated knock sensor that is different from the stock/earlier version. this .pdf is a guide for replacing models that need the new kit. this file is for a '94 turbo but according to the subtitle it applies to 92-- & up. i'm not sure about which models do or don't need the newer kit so make sure on your own about your model.
86 downloads
Submitted
Vacuum Elbows for for 850 (up to 10/95) and 850, 70 Series (11/95-2000)
By jefhon
install instructions for vac elbows
73 downloads
Submitted
850/V70/S70 evap r/r
By jefhon
this is a file for help replacing the A/C evaporator on models 850/V70/S70. it is in .pdf format. roger, over.
117 downloads
Submitted
v70-960-compare-0261204643_1037358993_9125573_1998_3L_S90.zip
By rkam
Excel spreadsheet comparing map addresses from V70 5-cyl with damos and S90 6-cyl without damos.
173 downloads
Submitted
Eastern Aerospace
Where have all the tuners gone? Remember Eastern Aerospace? Home of the 35hp throttle body.
197 downloads
Submitted
Submitted
Submitted
Submitted
Submitted
Submitted
Volvo 850 Flashers Flash On Lock
How to make the 850 turn signals flash when the car is locked
Thank Serge
250 downloads
Submitted
Carlisle 2010 Show Field Map
By gdizzle
For those that are regular attendees of the show, we're in our typical spot as always. For those that are first timers, you can view the show field via the PDF'd Map
87 downloads
Submitted
Updated
Submitted
Submitted
Volvo OEM Wheel Brochure 1993-2004
By Burn-E
Photos of Volvo Alloy Wheels - a single page designed by Volvo to show all OEM wheels available and the models they were sold with from 1993-2004.
255 downloads
Submitted
Submitted
Submitted
engine compartment
By jefhon
a shot of my mother's volvo: a turbo, 2008 S. i took the intake out to do the PCV. the intake has the bolts off & is loose but still sitting in the compartment so that we may see more of what, exactly, is going on in there. roger over. Cpt. Under Out.
58 downloads
Submitted
Updated
By rkam
Picture of M4.3 / M4.4 programming tool with extra unknown functions.
143 downloads
Submitted
Submitted
