JHEIII874T5M Posted October 20, 2008 Report Share Posted October 20, 2008 Did a couple strong pulls in 2nd and 3rd... would be rather interesting on bottle or boost. Link to comment Share on other sites More sharing options...
Livvakt Posted October 20, 2008 Report Share Posted October 20, 2008 Did a couple strong pulls in 2nd and 3rd... would be rather interesting on bottle or boost. GT22 in the Miata please :ph34r: Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted October 20, 2008 Report Share Posted October 20, 2008 GT22 in the Miata please Was thinking more T3/T04E Link to comment Share on other sites More sharing options...
Livvakt Posted October 20, 2008 Report Share Posted October 20, 2008 Was thinking more T3/T04EFUCK. :lol: Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted October 20, 2008 Report Share Posted October 20, 2008 50 Trim with a Tial 38, 1 bar spring. Water/meth, megasquirt PnP through DIYAutotune.com, and having a local welding guru make the manifold.Already have the Torsen Rear LSD and clutch/pp/lightened flywheel installed to handle transmission matters. Heck, the water/meth setup is sitting on the shelf from when I took it off the S70.300whp should be interesting in a 2100 pound car. :lol: Link to comment Share on other sites More sharing options...
Livvakt Posted October 20, 2008 Report Share Posted October 20, 2008 50 Trim with a Tial 38, 1 bar spring. Water/meth, megasquirt PnP through DIYAutotune.com, and having a local welding guru make the manifold.Already have the Torsen Rear LSD and clutch/pp/lightened flywheel installed to handle transmission matters. Heck, the water/meth setup is sitting on the shelf from when I took it off the S70.300whp should be interesting in a 2100 pound car. Uh, yes. Yes it will be I expect to see this bitch sometime soon! Link to comment Share on other sites More sharing options...
7 VII 7 Posted October 20, 2008 Report Share Posted October 20, 2008 is $500 for a full cyl block re-newel good?spoke to soon$67.50 to resurface the head$150 to dissemble the head and valvesthen it depends on what is wrong such as valves and all that Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted October 20, 2008 Report Share Posted October 20, 2008 spoke to soon$67.50 to resurface the head$150 to dissemble the head and valvesthen it depends on what is wrong such as valves and all that Valve jobs run about $300 usually on these heads... wonder what your guy is going to charge to reassemble the head & valves. Looks like you're already $210 in the holeSourcing new valve seals?Oh and what's up with you and the rebuild? Timing belt snap or something?May want to check this thread out for machining costs: http://volvospeed.com/vs_forum/index.php?showtopic=80202 Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted October 20, 2008 Report Share Posted October 20, 2008 different tint levels look bad do everything 5fixed.50 Trim with a Tial 38, 1 bar spring. Water/meth, megasquirt PnP through DIYAutotune.com, and having a local welding guru make the manifold.Already have the Torsen Rear LSD and clutch/pp/lightened flywheel installed to handle transmission matters. Heck, the water/meth setup is sitting on the shelf from when I took it off the S70.300whp should be interesting in a 2100 pound car. wow. that makes me happy. Link to comment Share on other sites More sharing options...
7 VII 7 Posted October 20, 2008 Report Share Posted October 20, 2008 Valve jobs run about $300 usually on these heads... wonder what your guy is going to charge to reassemble the head & valves. Looks like you're already $210 in the holeSourcing new valve seals?Oh and what's up with you and the rebuild? Timing belt snap or something?all OEM, not really worried about $$$ with this valve job since the guy is awesome and has been dealing with Don Beyer Volvo Dealership for years and years and years and years. I just want it done right.no, I am building something :) Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted October 20, 2008 Report Share Posted October 20, 2008 all OEM, not really worried about $$$ with this valve job since the guy is awesome and has been dealing with Don Beyer Volvo Dealership for years and years and years and years. I just want it done right.no, I am building something Good stuff, glad to hear things are being done in a proper manner. B) Link to comment Share on other sites More sharing options...
7 VII 7 Posted October 20, 2008 Report Share Posted October 20, 2008 Good stuff, glad to hear things are being done in a proper manner. yeah no issues so far... just trying to get things straightI am the kind of guy that measures 5 times and cuts 1 time.I have been doing a lot of research but still want to make sure everything is 100% before I spend 4k on this Link to comment Share on other sites More sharing options...
DonutsDemise Posted October 20, 2008 Report Share Posted October 20, 2008 good idea otherwise it would turn into 8k to do it twice, i would take notes while you're doing it too so you know what you've done and what you've missed. or make a checklist and sign off on everything as you do it. Link to comment Share on other sites More sharing options...
BtownVolvo Posted October 20, 2008 Report Share Posted October 20, 2008 Replaced the plugs Friday. Car runs 100000000000x better. Link to comment Share on other sites More sharing options...
7 VII 7 Posted October 20, 2008 Report Share Posted October 20, 2008 good idea otherwise it would turn into 8k to do it twice, i would take notes while you're doing it too so you know what you've done and what you've missed. or make a checklist and sign off on everything as you do it.yeah, I will remember everythingfor the wires and all that jazz I am just lettering them to where they go A to A, B to B ect. Link to comment Share on other sites More sharing options...
