Marius850R Posted January 6, 2010 Report Share Posted January 6, 2010 hey looking for people sugestions , just got a set of N/A cams from 850 1994 20v .... should i just change the intake or should change both on my 850 T5-R with K24 turbo .... Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted January 6, 2010 Report Share Posted January 6, 2010 hey looking for people sugestions , just got a set of N/A cams from 850 1994 20v .... should i just change the intake or should change both on my 850 T5-R with K24 turbo .... I did both, others have done just one Quote Link to comment Share on other sites More sharing options...
troyhyde Posted January 7, 2010 Report Share Posted January 7, 2010 I was doing some reading on this same subject. Johann (who seems to have some chops with these cars) suggested in an older post to only use the NA intake cam. I figured his suggestion was from a reliable source. Quote Link to comment Share on other sites More sharing options...
GeraldJ Posted January 7, 2010 Report Share Posted January 7, 2010 Im only using the intake. Wouldnt know how well its running I did a lot of upgrades at once. Quote Link to comment Share on other sites More sharing options...
Marius850R Posted January 7, 2010 Author Report Share Posted January 7, 2010 so then i will just put in the intake cam for now and try later with the exhaust i will see the difference.... Quote Link to comment Share on other sites More sharing options...
TurboedVolvo Posted January 7, 2010 Report Share Posted January 7, 2010 so then i will just put in the intake cam for now and try later with the exhaust i will see the difference.... Worth a shot! Let us know your results! Quote Link to comment Share on other sites More sharing options...
Marius850R Posted January 7, 2010 Author Report Share Posted January 7, 2010 Worth a shot! Let us know your results! i will by end off next week !! Quote Link to comment Share on other sites More sharing options...
gilber33 Posted January 7, 2010 Report Share Posted January 7, 2010 By just using the intake n/a cam does that provide a more even power spread? Quote Link to comment Share on other sites More sharing options...
v4lve Posted January 7, 2010 Report Share Posted January 7, 2010 By just using the intake n/a cam does that provide a more even power spread? kind of, can make adjustments to the powerband. Advance for more low-end or retard for more high end. I'd also like to do this in the near future, to those who did both how big of an issue was overlap and what would you say your actual adjustment was? Quote Link to comment Share on other sites More sharing options...
gilber33 Posted January 7, 2010 Report Share Posted January 7, 2010 kind of, can make adjustments to the powerband. Advance for more low-end or retard for more high end. I'd also like to do this in the near future, to those who did both how big of an issue was overlap and what would you say your actual adjustment was? What is the range of the low end power band? Does that mean that you entirely loose your high end power, or it's just turned down a bit?It seems like there's a lot of unknowns with the NA cams. Quote Link to comment Share on other sites More sharing options...
TurboedVolvo Posted January 7, 2010 Report Share Posted January 7, 2010 What is the range of the low end power band? Does that mean that you entirely loose your high end power, or it's just turned down a bit? It seems like there's a lot of unknowns with the NA cams. No, All it simply does is shift the power band slightly... It is known to the community that about 15hp is gained from switching to NA Cams (Yet its hard to find exactly what setup, intake only both or exhaust) Advancing and Retarding Cam timing makes a huge difference in the powerband though! So be careful how much you advance/retardand considering you can find a set of N/A for about 20$ a set at a local junkyard thats almost 1$ per HP, if only everything was that cheap! Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted January 7, 2010 Report Share Posted January 7, 2010 kind of, can make adjustments to the powerband. Advance for more low-end or retard for more high end. I'd also like to do this in the near future, to those who did both how big of an issue was overlap and what would you say your actual adjustment was? I set the cams at the stock turbo settings, which is about 4º adv EXH 0º INT Quote Link to comment Share on other sites More sharing options...
bum2kev Posted January 7, 2010 Report Share Posted January 7, 2010 there was a lot of info on the QBM website about cams. its all gone now :( Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted January 7, 2010 Report Share Posted January 7, 2010 there was a lot of info on the QBM website about cams. its all gone now I downloaded the PDF. I can always email it. I have no way of web-hosting PDF files. Same goes for the Mitsubishi Turbo Rebuild Guide - great reference for anyone doing it for the first time. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted January 8, 2010 Report Share Posted January 8, 2010 I downloaded the PDF. I can always email it. I have no way of web-hosting PDF files. Same goes for the Mitsubishi Turbo Rebuild Guide - great reference for anyone doing it for the first time. If you could email it to me, that would be great. My email's in my profile. Quote Link to comment Share on other sites More sharing options...
