Livvakt Posted July 17, 2008 Report Share Posted July 17, 2008 So I just recieved my "new" ECC unit, and put it in the car.... Everything fires up fine, but for whatever reason, the auto feature both on the fan speed and the vent positioner aren't working... it won't... auto, lol.Also, there's now an audible "click" from under the hood when the AC turns off (sometimes on, but mostly off, like when i turn the car off).Thoughts? Link to comment Share on other sites More sharing options...
Oreo931 Posted July 17, 2008 Report Share Posted July 17, 2008 Also, there's now an audible "click" from under the hood when the AC turns off (sometimes on, but mostly off, like when i turn the car off).Thoughts?The clicking sound is most likely the compressor cycling. It clicks once when it cycles on, and once again when it cycles off. It should cycle every 30 seconds to a minute, give or take. Its completely normal.Do you know if you have any fault codes for the climate control system? I forget which port it is on the OBDI reader thing, but you should check for fault codes and possibly try to reset them if you can, Link to comment Share on other sites More sharing options...
Livvakt Posted July 17, 2008 Author Report Share Posted July 17, 2008 The clicking sound is most likely the compressor cycling. It clicks once when it cycles on, and once again when it cycles off. It should cycle every 30 seconds to a minute, give or take. Its completely normal.Do you know if you have any fault codes for the climate control system? I forget which port it is on the OBDI reader thing, but you should check for fault codes and possibly try to reset them if you can,To the best of my knowledge I'm not throwing any... but I'll swing by Forge and have 'em plug me in and take a look :) Link to comment Share on other sites More sharing options...
Oreo931 Posted July 17, 2008 Report Share Posted July 17, 2008 To the best of my knowledge I'm not throwing any... but I'll swing by Forge and have 'em plug me in and take a look I'm not talking about the OBDII port near your cig lighter. I am talking about the diagnostic box under the hood. There are instructions in the Bay13 maintenance section on how to read the codes (if you have any), as well as which socket to use. Link to comment Share on other sites More sharing options...
Livvakt Posted July 17, 2008 Author Report Share Posted July 17, 2008 I'm not talking about the OBDII port near your cig lighter. I am talking about the diagnostic box under the hood. There are instructions in the Bay13 maintenance section on how to read the codes (if you have any), as well as which socket to use.I know about that little guy, I just figured the OBDII would be easier, lol... ... That, and it's POURING here right now, haha. No outside for me :) Link to comment Share on other sites More sharing options...
Oreo931 Posted July 17, 2008 Report Share Posted July 17, 2008 I know about that little guy, I just figured the OBDII would be easier, lol... ... That, and it's POURING here right now, haha. No outside for me Have you ever heard that annoying song? "Under my umbrella... ELLA ELLA ELLA ELLA":P Link to comment Share on other sites More sharing options...
Livvakt Posted July 17, 2008 Author Report Share Posted July 17, 2008 Have you ever heard that annoying song? "Under my umbrella... ELLA ELLA ELLA ELLA"lol :P Link to comment Share on other sites More sharing options...
