NWC70 Posted July 21, 2008 Report Share Posted July 21, 2008 I was told that if I touch the + & - battery cables together for 5 minutes that this will reset the ecu. Has anyone done this before? Will it overide my recent Volvo dealer download for the EMS problem?Should the car be able to rev over 4,500 RPM in neutral? Car can hold 9psi but there is almost no acceleration and the car is very bogged down.I had been following this thread: http://volvospeed.com/vs_forum/index.php?showtopic=99816I'll be working on the car this afternoon and inspecting the VVT solenoid. Link to comment Share on other sites More sharing options...
maiku Posted July 21, 2008 Report Share Posted July 21, 2008 if you touch the + and - battery terminals together you'll likely short out the battery, the car electronics, and possibly kill yourself Link to comment Share on other sites More sharing options...
NWC70 Posted July 21, 2008 Author Report Share Posted July 21, 2008 if you touch the + and - battery terminals together you'll likely short out the battery, the car electronics, and possibly kill yourselfI'm sure that is true for the battery terminals but I said battery cables. If the battery is out of the car where will it get power from to shock me? Link to comment Share on other sites More sharing options...
mr. volvo Posted July 21, 2008 Report Share Posted July 21, 2008 I'm sure that is true for the battery terminals but I said battery cables. If the battery is out of the car where will it get power from to shock me?It wont, and that is exactly what to do, its function is dumping all the capacitors in the control modules, its referred to as a battery reset. 5 minutes is unnecessary, just a momentary touch or two will do the job. Tim ChildersVolvo Of Hickory Link to comment Share on other sites More sharing options...
Hastings Posted July 21, 2008 Report Share Posted July 21, 2008 It wont, and that is exactly what to do, its function is dumping all the capacitors in the control modules, its referred to as a battery reset. 5 minutes is unnecessary, just a momentary touch or two will do the job. Tim ChildersVolvo Of HickoryNWC70 - Just be careful, If I were you I'd call my local volvo dealer and ask the same question to a guy in the garage, their usually friendly and will tell you. Can't always trust what you hear online ;) Link to comment Share on other sites More sharing options...
NWC70 Posted July 21, 2008 Author Report Share Posted July 21, 2008 NWC70 - Just be careful, If I were you I'd call my local volvo dealer and ask the same question to a guy in the garage, their usually friendly and will tell you. Can't always trust what you hear online Yah, thanks for the input but i'm assuming that Tim does work at a dealership. I don't trust the Tacoma volvo dealership anyways, they either have no idea whats going on or are mad because they broke my seatbelt and had to fix it.Did you ever check your vin to see if you had an HPT? Link to comment Share on other sites More sharing options...
Hastings Posted July 22, 2008 Report Share Posted July 22, 2008 Yah, thanks for the input but i'm assuming that Tim does work at a dealership. I don't trust the Tacoma volvo dealership anyways, they either have no idea whats going on or are mad because they broke my seatbelt and had to fix it.Did you ever check your vin to see if you had an HPT?Yessir, it's LPT.Back on topic: I'd still give volvo a call, though - Call volvo of tucson arizona, their really friendly there, and they seem to know what their talking about. (520) 792-1070 is their number. Link to comment Share on other sites More sharing options...
mr. volvo Posted July 22, 2008 Report Share Posted July 22, 2008 Yah, thanks for the input but i'm assuming that Tim does work at a dealership. I don't trust the Tacoma volvo dealership anyways, they either have no idea whats going on or are mad because they broke my seatbelt and had to fix it.Did you ever check your vin to see if you had an HPT?You can trust me. I do work for the volvo dealership, and have for the past 20 plus years. The last 18 years as a technician, now i have moved up front to the service drive.The battery reset procedeure I mentioned is a valid, safe, and useful tip for modern car's electronic system hiccups. I have been suprised at the things this has fixed for us here. Never hurts to try this. Tim ChildersVolvo Of Hickory Link to comment Share on other sites More sharing options...
NWC70 Posted July 22, 2008 Author Report Share Posted July 22, 2008 You can trust me. I do work for the volvo dealership, and have for the past 20 plus years. The last 18 years as a technician, now i have moved up front to the service drive.The battery reset procedeure I mentioned is a valid, safe, and useful tip for modern car's electronic system hiccups. I have been suprised at the things this has fixed for us here. Never hurts to try this. Tim ChildersVolvo Of HickoryThanks Tim. I did the battery reset and it got rid of the rev limiter. Found out the problem was a bad MAF sensor, car runs so much better with it unplugged. Will be replacing. Link to comment Share on other sites More sharing options...
V70glturbo Posted July 23, 2008 Report Share Posted July 23, 2008 Thanks Tim. I did the battery reset and it got rid of the rev limiter. Found out the problem was a bad MAF sensor, car runs so much better with it unplugged. Will be replacing.not to thread jack....but does this work for the SRS light?? Link to comment Share on other sites More sharing options...
mr. volvo Posted July 23, 2008 Report Share Posted July 23, 2008 not to thread jack....but does this work for the SRS light??no, sorry, but it wont. those codes are burned in, and must be forcibly erased. Tim ChildersVolvo Of Hickory Link to comment Share on other sites More sharing options...
MrWinkey Posted July 25, 2008 Report Share Posted July 25, 2008 if you touch the + and - battery terminals together you'll likely short out the battery, the car electronics, and possibly kill yourselfBuzzzzzzzzzzsssssssssstttt! :excl: Link to comment Share on other sites More sharing options...
