bmx9854 Posted July 27, 2008 Report Share Posted July 27, 2008 I have gotten all the bolts and nuts of of the starter, I think. Two bolts on the front and two nuts off the back are what I've taken off. I have been trying to work it out by banging it with a block of wood and hammer and it hasn't really budged. Did I miss a bolt or something? Link to comment Share on other sites More sharing options...
prasamin Posted July 27, 2008 Report Share Posted July 27, 2008 did you take the bracket off? Link to comment Share on other sites More sharing options...
KlausC Posted July 27, 2008 Report Share Posted July 27, 2008 The starter motor is pulled off the bracket towards the passenger side of the car. There is a stud in the motor that sticks through the mounting bracket. Link to comment Share on other sites More sharing options...
Ozark Lee Posted July 28, 2008 Report Share Posted July 28, 2008 Your next trick (after you remove the bracket) will be to get the starter out of the car.It can be done but it is a PITA....Lee Link to comment Share on other sites More sharing options...
mr. volvo Posted July 28, 2008 Report Share Posted July 28, 2008 The starter motor is pulled off the bracket towards the passenger side of the car. There is a stud in the motor that sticks through the mounting bracket.Its not a stud, its a single 12mm bolt, that affixes the bracket to the block. the two 10mm nuts, affix the bracket to the starter. the need not be removed, but the 12mm bolt must be removed. The starter is not much of a pita, imo. thats a really easy job on those cars. Hell of a lot easier and cleaner than RWD redblock cars. Link to comment Share on other sites More sharing options...
bmx9854 Posted July 28, 2008 Author Report Share Posted July 28, 2008 I'll try taking off that bracket then tomorrow afternoon. Thanks Link to comment Share on other sites More sharing options...
