scandalo Posted July 30, 2008 Report Share Posted July 30, 2008 Topic says it. Reading many threads and getting many answers but nothing concrete.The situation is as such:-No MPG loss apparent-No performance loss apparent-No visible or audible signs of air leak (but am not willing to rule that out)-Replaced fuel pump to filter hose with a basic injector hose with a slightly larger diameter (cheaper than the 100 dollar dealer alternative)-Vacuum loss at cold start with symptoms of stallingWondering if it is the air pump/sas or something more abstract.I may have left something out. Ask away please! Link to comment Share on other sites More sharing options...
7 VII 7 Posted July 30, 2008 Report Share Posted July 30, 2008 Topic says it. Reading many threads and getting many answers but nothing concrete.The situation is as such:-No MPG loss apparent-No performance loss apparent-No visible or audible signs of air leak (but am not willing to rule that out)-Replaced fuel pump to filter hose with a basic injector hose with a slightly larger diameter (cheaper than the 100 dollar dealer alternative)-Vacuum loss at cold start with symptoms of stallingWondering if it is the air pump/sas or something more abstract.I may have left something out. Ask away please!Check this one... Link to comment Share on other sites More sharing options...
scandalo Posted July 30, 2008 Author Report Share Posted July 30, 2008 Dave, you get the cookie. That hose is torn from the nipple to the elbow. I don't have time to see where it leads so I need to know if it is a special hose or I can rig something cheap.EDIT: Nevermind. I read a little more in depth and realized it was just a elbow to one of the plastic lines. Link to comment Share on other sites More sharing options...
7 VII 7 Posted July 31, 2008 Report Share Posted July 31, 2008 Dave, you get the cookie. That hose is torn from the nipple to the elbow. I don't have time to see where it leads so I need to know if it is a special hose or I can rig something cheap.EDIT: Nevermind. I read a little more in depth and realized it was just a elbow to one of the plastic lines.if you have not done a PCV replacement and you are over 70k miles, this is a great opportunity to fix the elbow and do the PCV system which will help your car keep from breaking a RMS Link to comment Share on other sites More sharing options...
scandalo Posted August 4, 2008 Author Report Share Posted August 4, 2008 CEL came back. Any other ideas? Replaced the O2 sensor when I first got this code so we are good there.RMS=rear main seal? Link to comment Share on other sites More sharing options...
7 VII 7 Posted August 4, 2008 Report Share Posted August 4, 2008 CEL came back. Any other ideas? Replaced the O2 sensor when I first got this code so we are good there.RMS=rear main seal?RMS is the Rear Main Sealare you good on your spark plugs? are they gaped correctly? Link to comment Share on other sites More sharing options...
scandalo Posted August 5, 2008 Author Report Share Posted August 5, 2008 checked the spark plugs a when i first got it but none of them were black. Gap im not sure about. What is the gap for sparks? Link to comment Share on other sites More sharing options...
7 VII 7 Posted August 5, 2008 Report Share Posted August 5, 2008 checked the spark plugs a when i first got it but none of them were black. Gap im not sure about. What is the gap for sparks?umm... i think my NA OEM ones are gapped to 0.028 or 0.026 or 0.024... people running higher boost or turbo cars can fun a smaller gap around 0.024 Link to comment Share on other sites More sharing options...
Oreo931 Posted August 5, 2008 Report Share Posted August 5, 2008 umm... i think my NA OEM ones are gapped to 0.028 or 0.026 or 0.024... people running higher boost or turbo cars can fun a smaller gap around 0.024stock gap is ~.028 Link to comment Share on other sites More sharing options...
