blazen244 Posted August 14, 2008 Report Share Posted August 14, 2008 I have a intake manifold I was looking to get the N/A thottle body I understand those are larger, I need to know if it is worth while to have the intake manifold ported to the size of the thottle body and what kind of gains would I likely see Link to comment Share on other sites More sharing options...
troyhyde Posted August 14, 2008 Report Share Posted August 14, 2008 None probably.You can stuff a lot of air through the stock turbo piping (provided you put a larger turbo on). You will be able to destroy the engine waaaayy before the throttle body becomes a restriction to your performance. Link to comment Share on other sites More sharing options...
socal850tuner Posted August 14, 2008 Report Share Posted August 14, 2008 in fact the reason the turbo throttle body is smaller is that it helps build boost quicker. Link to comment Share on other sites More sharing options...
kez Posted August 14, 2008 Report Share Posted August 14, 2008 I have a intake manifold I was looking to get the N/A thottle body I understand those are larger, I need to know if it is worth while to have the intake manifold ported to the size of the thottle body and what kind of gains would I likely see morning blaze if you use the throttle body from the 960 its lots of hassel with the plumbingkez Link to comment Share on other sites More sharing options...
