Chexjc Posted August 16, 2008 Report Share Posted August 16, 2008 Ever since a minor hit and run incident, which I suspect happened in a parking lot (didn't notice until I got home - medium-sized dent over rear left wheel), my 2000 S80 T6 randomnly displays a "NSTC Service Needed" message. What does this mean and how can I fix it?Thanks,Jason. Link to comment Share on other sites More sharing options...
vegasjetskier Posted August 16, 2008 Report Share Posted August 16, 2008 I don't know about NSTC, but STC stands for Stability Traction Control and DSTC stands for Dynamic Stability and Traction Control. Link to comment Share on other sites More sharing options...
Chexjc Posted August 16, 2008 Author Report Share Posted August 16, 2008 I don't know about NSTC, but STC stands for Stability Traction Control and DSTC stands for Dynamic Stability and Traction Control.Doh', that is what I meant to say. I guess it doesn't appear frequently enough for me to know what I'm talking about. Link to comment Share on other sites More sharing options...
Chexjc Posted August 16, 2008 Author Report Share Posted August 16, 2008 Thanks by the way, that has made my search results quite a bit more effective, haha. Link to comment Share on other sites More sharing options...
vegasjetskier Posted August 16, 2008 Report Share Posted August 16, 2008 Well according to the manual this warning might show if one of the brakes has been too hot. But, I can't see how a small fender dent would heat up your brakes. You might pull the wheels and take a look to see if one of the brake pads has been hanging up, and make sure that all the ABS wires are still intact. Also, the manual says to take it to the dealer to have it checked out if it persists. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted August 18, 2008 Report Share Posted August 18, 2008 You need to have the actual codes read from the ABS module, but I would guess the message is not related to the accident, rather you have an ABS module that is on the way out. Link to comment Share on other sites More sharing options...
fightinchunk Posted August 18, 2008 Report Share Posted August 18, 2008 so what does the message say, DSTC or TRACS? I ge the DSTC message almost everytime I drive... but I just end up turning it off anyway. I originally thought it was one of the yaw sensors, but those checked out when teknicktion plugged my car into vadis. From what I've heard, you can actually send out these modules to get rebuilt for alot less than a whole new computer. Link to comment Share on other sites More sharing options...
Chexjc Posted August 19, 2008 Author Report Share Posted August 19, 2008 Thanks for the input guys. The message reads "DSTC Service Needed." It happens about every other time I drive. Link to comment Share on other sites More sharing options...
smokin' T5M Posted August 19, 2008 Report Share Posted August 19, 2008 Have the rear suspension inspected and make sure the toe arm in the back hasn't been bent. Also make sure that the DSTC sensor hasn't gotten water damage. The sunroof drains can leak and damage the DSTC unit under the R/F seat. Link to comment Share on other sites More sharing options...
Chexjc Posted August 19, 2008 Author Report Share Posted August 19, 2008 Have the rear suspension inspected and make sure the toe arm in the back hasn't been bent. Also make sure that the DSTC sensor hasn't gotten water damage. The sunroof drains can leak and damage the DSTC unit under the R/F seat.Sounds good. My sunroof did shatter, or rupture I should say last summer. I covered it with a tarp when it rained until it was fixed though, haha. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted August 19, 2008 Report Share Posted August 19, 2008 Have the rear suspension inspected and make sure the toe arm in the back hasn't been bent. Also make sure that the DSTC sensor hasn't gotten water damage. The sunroof drains can leak and damage the DSTC unit under the R/F seat.True story. Link to comment Share on other sites More sharing options...
