Falcone Posted August 20, 2008 Author Report Share Posted August 20, 2008 the toggle is to simulate the e-brake being engaged/dis-engaged to enable movie play. If you ground it to the ground wire of the unit (black) it works perfect. Maybe it has something to do with the splicing of the brightness wire you did, as I did not do that. cheers Link to comment Share on other sites More sharing options...
Chrisonfire Posted August 20, 2008 Report Share Posted August 20, 2008 Would like to see some install pictures. I am picking up this HU for my s70. Link to comment Share on other sites More sharing options...
Chilled man Posted August 20, 2008 Report Share Posted August 20, 2008 the toggle is to simulate the e-brake being engaged/dis-engaged to enable movie play. If you ground it to the ground wire of the unit (black) it works perfect. Maybe it has something to do with the splicing of the brightness wire you did, as I did not do that. cheersagreed that is what I am thinking they didnt you stand alone ground and just used any ground or complete opisit I just used the ground for the radio when I did mine :lol: Link to comment Share on other sites More sharing options...
Falcone Posted August 20, 2008 Author Report Share Posted August 20, 2008 I added a toggle switch to mine today, so its not grounded all the time. Its the kind with three connections on the bottom, two for on, one for off, and locks into position. Initally I had a pust button on/off in one click, but it didn't do the trick. This particular unit must be grounded the entire time you intend to watch movies. The first time I hooked it up I used the actual ground of the radio as per bo-peep, was super easy and fast, but Ihave to say I like toggle switches. Took some pictures today of the re-re-re-install, but when I got back upstairs to upload the pictures, my usb cable had been molested by my cats and is in three good pieces, I'll post pics tomorrow.previous install with push button switchold test fit Link to comment Share on other sites More sharing options...
