turbomoose Posted August 21, 2008 Report Share Posted August 21, 2008 Ok, so this has been going on for a month. If I make a right turn, from a stop, or rolling stop, then FLOOR it, my car hesitates, bucks.At first I thought it was the TRACS cutting the fuel or engine power because I was losing traction. But today I had the TRACS OFF, and it does it.Here's the conditions:ALWAYS on a right turn under heavy acceleration (80-100%)I have steady full boost, but no movement. My RPMS go up to about 2.5K, and hold steady, but there's a jerky, no power feel.Does it in both Econ and Sport modes. Tracs on or off.I'm using 93 octane, mobil 1 10w-30, Replaced the cap&rotor, temp sender, it has Volvo spark plugs, new volvo fuel & air filters, complete new PCV system done 15K ago.I"m not sure if it does it only when I have a full tank. But I have a full tank now, and I noticed it when I was leaving the gas station last time I filled up.What else is there to check?? Link to comment Share on other sites More sharing options...
turbomoose Posted August 21, 2008 Author Report Share Posted August 21, 2008 RuhOH. So I wanted to try making a right turn with the transmission only in 1st gear. I thought the tranny may be hunting for a gear, causing the hesitation. So I read the owners manual and it says engage Winter, then shift into L to hold 1st gear.So I started my car. Engaged Winter mode. Reversed out of my garage. Put the car in L to hold 1st gear, the Arrow of death started flashing and the CEL came on. I crapped my shorts, de-engaged winter, shifted into Drive, and pulled back into my garage. I've disconnected the battery and removed the ECM and TCM. I've rowed the shifter between P and L several times, I've never done this before. And I dont think I've ever shifted into L before either. I think I just somehow ruined my tranny. Whoops. What do I do now?? Call a tow truck or a wrecker?? Link to comment Share on other sites More sharing options...
turbomoose Posted August 21, 2008 Author Report Share Posted August 21, 2008 ok, so I reconnected everything and the flashing arrow went away... but now I have a CEL. So Im gonna scan that right now and see what's what. :rolleyes: Link to comment Share on other sites More sharing options...
turbomoose Posted August 21, 2008 Author Report Share Posted August 21, 2008 I had a Gear Range code. PNP switch. The guy got the CEL to go off, and oddly, I can not reproduce the hesitation. I'm thinking MAYBE my PNP was dirty, and when I'd make a hard right, the engine/transmission would move around enough to disturb the contacts in the PNP switch, causing a hesitation within the tranny.SO now all's well, I have no lights on, and it doesn't burp anymore!Thanks for reading along kids. :D Link to comment Share on other sites More sharing options...
Austin H Posted August 24, 2008 Report Share Posted August 24, 2008 Do your backup lights work? Link to comment Share on other sites More sharing options...
turbomoose Posted August 24, 2008 Author Report Share Posted August 24, 2008 Yes, there was never an issue with the BU lights. Just a hesitation, which has been resolved, thanks. Link to comment Share on other sites More sharing options...
