9883 Posted August 29, 2008 Report Share Posted August 29, 2008 Why did this happen? Should I toss them all? I was following the specs printed by Volvo in the owner's manual. Link to comment Share on other sites More sharing options...
DonutsDemise Posted August 29, 2008 Report Share Posted August 29, 2008 how much torque did you put on that? and do you have a stud adapter or studs are stock? Link to comment Share on other sites More sharing options...
9883 Posted August 29, 2008 Author Report Share Posted August 29, 2008 stud conversion, 81 ft.lbs. Link to comment Share on other sites More sharing options...
DonutsDemise Posted August 29, 2008 Report Share Posted August 29, 2008 hmmm, that would worry me enough to go to the bolts at least on the front axle. i guess you have to at least take that converter off. Link to comment Share on other sites More sharing options...
9883 Posted August 29, 2008 Author Report Share Posted August 29, 2008 ok. I know now why this happened. There is a defect in the thread that does not allow the stud to thread fully into the lug nut. It forces the nut to stop threading before the correct torque spec is reached. It was stuck and the nut was not able to make a closer contact with the wheel. When I put more force it did not tighten but rather snapped. Link to comment Share on other sites More sharing options...
flyfishing3 Posted August 30, 2008 Report Share Posted August 30, 2008 is your real name david banner? Link to comment Share on other sites More sharing options...
matt b Posted August 30, 2008 Report Share Posted August 30, 2008 If they did not hold up to 81 lbs/ft, you might want to start worrying. :huh: Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 30, 2008 Report Share Posted August 30, 2008 QUOTE (matt b @ Aug 29 2008, 08:09 PM) If they did not hold up to 81 lbs/ft, you might want to start worrying. Yeah thats not grade correct hardware. If it were, the hub would have stripped before that happened. Even a mis cut thread would only do that if installed with an impact driver. Link to comment Share on other sites More sharing options...
9883 Posted August 30, 2008 Author Report Share Posted August 30, 2008 What options are there? Found only one place to get studs for volvo? There is some vendor that I have seen mentioned on here but people had problems with those also. As far as quality of hardware is concerned it can't be all that great because the price was low but it has to meet some standards and be safe to use. Link to comment Share on other sites More sharing options...
matt b Posted August 30, 2008 Report Share Posted August 30, 2008 I have spares, if you need something to get your car back on the road, shoot me a PM with your address and I'll mail them Wednesday when I get home. Link to comment Share on other sites More sharing options...
9883 Posted August 30, 2008 Author Report Share Posted August 30, 2008 The volvo is just a side attraction. Got and mkv gti for DD. How much for the spares? Are they also from that seller on ebay? Link to comment Share on other sites More sharing options...
matt b Posted August 30, 2008 Report Share Posted August 30, 2008 The volvo is just a side attraction. Got and mkv gti for DD. How much for the spares? Are they also from that seller on ebay?My spares are OEM parts. I have accumulated lug bolts over the years and I don't mind sending them to you for the cost of postage. I have about 40 spares now if you need a few, just let me know. Link to comment Share on other sites More sharing options...
