Volvo Virgin Posted September 1, 2008 Report Share Posted September 1, 2008 Posted up a couple weeks ago about adjustment on the emergency brake. Chuck was good enough to clue me in on the adjustment from the center console. Finally got to that today, but it still won't stop the car or even hold it from a dead stop just putting the car in gear with no throttle. I can hear the e-brake dragging when it's on, but that's all the action I get.So on to plan b(not Grant ). I'm sure I can figure it out when I pull it apart, but figured a heads up before heading in wouldn't hurt. Any thoughts on what I'm likely to find as the culprit or what to look out for?Thanks,Rob Link to comment Share on other sites More sharing options...
Black Betty Posted September 1, 2008 Report Share Posted September 1, 2008 just take off the rotor ill let you know what i found when i did the same thing because i had the same issueright side no brak hardware what so ever only the cable no springs or anythingleft side no shoes rest of brake hardware still there good luck! Link to comment Share on other sites More sharing options...
Volvo Virgin Posted September 2, 2008 Author Report Share Posted September 2, 2008 just take off the rotor ill let you know what i found when i did the same thing because i had the same issueright side no brak hardware what so ever only the cable no springs or anythingleft side no shoes rest of brake hardware still there good luck!Thanks for the well wishes. I know mine were intact when I did the rear brakes last time about 1.5 years ago and cut the rotors. Tough for me to believe the e-brake shoes wore out when you only use the freakin thing after you stop. I do use it regularly tho as my driveway is on a hill, and it was just getting weaker and weaker to the point where it didn't work at all.Any other thoughts?? Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted September 2, 2008 Report Share Posted September 2, 2008 Thanks for the well wishes. I know mine were intact when I did the rear brakes last time about 1.5 years ago and cut the rotors. Tough for me to believe the e-brake shoes wore out when you only use the freakin thing after you stop. I do use it regularly tho as my driveway is on a hill, and it was just getting weaker and weaker to the point where it didn't work at all.Any other thoughts??loosen up the cable and then pull the wheels off. Roll the rotor over so the 1/4"hole is about noon and use the adjuster wheel to tighten the shoes up to the drum. Once this adjustment is done, then use the cable adjustment for the rest. Link to comment Share on other sites More sharing options...
Volvo Virgin Posted September 2, 2008 Author Report Share Posted September 2, 2008 loosen up the cable and then pull the wheels off. Roll the rotor over so the 1/4"hole is about noon and use the adjuster wheel to tighten the shoes up to the drum. Once this adjustment is done, then use the cable adjustment for the rest.Now that's the kind of info I was looking for!! Thanks. Link to comment Share on other sites More sharing options...
mbsl98 Posted September 2, 2008 Report Share Posted September 2, 2008 When you get into the rear mechanics, be sure to check that the e-brake cables on both sides are not frozen inside their plastic covers. There are two separate cables that run from the center console under the back floor rug to the outside, and then in a curve back to the rear wheels. The covers frequently crack, letting moisture get into the metal interior and rust the cable. The end result can be either a very hard to move cable, or a cable that doesn't move at all. The interior handle will go up and down, but nothing happens at the other end of cable. Just have someone move the handle up and down while you watch and feel the action back at teh brake end.Note that the Volvo e-brake will not stop the car at the best of times. It is designed solely to hold it stationary once stopped. It does this very well, but will just barely slow teh car from speed. Link to comment Share on other sites More sharing options...
Volvo Virgin Posted September 2, 2008 Author Report Share Posted September 2, 2008 When you get into the rear mechanics, be sure to check that the e-brake cables on both sides are not frozen inside their plastic covers. There are two separate cables that run from the center console under the back floor rug to the outside, and then in a curve back to the rear wheels. The covers frequently crack, letting moisture get into the metal interior and rust the cable. The end result can be either a very hard to move cable, or a cable that doesn't move at all. The interior handle will go up and down, but nothing happens at the other end of cable. Just have someone move the handle up and down while you watch and feel the action back at teh brake end.Note that the Volvo e-brake will not stop the car at the best of times. It is designed solely to hold it stationary once stopped. It does this very well, but will just barely slow teh car from speed.More good info.Thanks.Seems Volvo missed the point of the "emergency" brake Link to comment Share on other sites More sharing options...
