echristodo Posted September 2, 2008 Report Share Posted September 2, 2008 I have a '99 V70XC that is in need of an engine. There is a VIN split for that year where if you have 56 as the sixth and seventh digit of the VIN you get one engine, and 55 you get another. Unfortunately I have the 56 which means my car takes a B5254T 2.4L engine that happens to be significantly more expensive than the 55 option, which is a B5254S. My question is: will either of these motors work, or must I spend the extra cheese and get the 'correct' engine. I need to know definatively! No opinions or "should work"... once this guy gets delivered there are no refunds! The date the car was put into service was 10/22/98.... Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted September 2, 2008 Report Share Posted September 2, 2008 I have a '99 V70XC that is in need of an engine. There is a VIN split for that year where if you have 56 as the sixth and seventh digit of the VIN you get one engine, and 55 you get another. Unfortunately I have the 56 which means my car takes a B5254T 2.4L engine that happens to be significantly more expensive than the 55 option, which is a B5254S. My question is: will either of these motors work, or must I spend the extra cheese and get the 'correct' engine. I need to know definatively! No opinions or "should work"... once this guy gets delivered there are no refunds! The date the car was put into service was 10/22/98....B5254S=non turbo Link to comment Share on other sites More sharing options...
echristodo Posted September 2, 2008 Author Report Share Posted September 2, 2008 B5254S=non turboWow, there is our problem then... it would appear that XC motors are expensive then, cause the 2.3T5 engines are cheap. F**k Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted September 2, 2008 Report Share Posted September 2, 2008 Wow, there is our problem then... it would appear that XC motors are expensive then, cause the 2.3T5 engines are cheap. F**kHPT XC? :lol: Link to comment Share on other sites More sharing options...
echristodo Posted September 2, 2008 Author Report Share Posted September 2, 2008 HPT XC? Although fun I think that might be a bit more complicated than what we are looking to do!Although it would look cool to throw some perfo's on it if it had the speed... Link to comment Share on other sites More sharing options...
