NEU Posted September 10, 2008 Report Share Posted September 10, 2008 When I added TME spring and Bilstien HD I had an alignment done and mine was within spec since HD struts raises the front because they are filled with high pressure nitrogen... Link to comment Share on other sites More sharing options...
matt b Posted September 10, 2008 Report Share Posted September 10, 2008 Both of my cars are lowered, just like others I've had, never had to do more than an alignment. You should really start with that, most places don't charge you a dime if they can't get it within specs anyway. Link to comment Share on other sites More sharing options...
PhilippineT5 Posted September 10, 2008 Report Share Posted September 10, 2008 QUOTE (matt b @ Sep 11 2008, 02:10 AM) <{POST_SNAPBACK}>Both of my cars are lowered, just like others I've had, never had to do more than an alignment. You should really start with that, most places don't charge you a dime if they can't get it within specs anyway.true.. start w/ the basics :D Link to comment Share on other sites More sharing options...
T-5Bandit Posted September 10, 2008 Report Share Posted September 10, 2008 Try an alignment shop that will actually adjust your front camber, there is no adjustment for rear camber. Most of the chain shops will try to tell you there is no camber adjustment, when there actually is a little through the spindle bolts. Camber kits are useless with standard lowering springs. Link to comment Share on other sites More sharing options...
b3atboxjr Posted September 10, 2008 Report Share Posted September 10, 2008 what exactly does a camber kit allow for? Link to comment Share on other sites More sharing options...
T-5Bandit Posted September 11, 2008 Report Share Posted September 11, 2008 what exactly does a camber kit allow for?A camber kit is really only an eccentric bolt (lobed bolt) that will allow for up to another 1-2 degrees of negative or positive camber. Excessive negative camber on these cars, even when very low on coilovers, is pretty rare. I sit just over 2 1/2 inches lower than stock and I have never required a camber kit. My camber is adjusted to -1 degrees just off the stock bolts, which is still within the factory specs.Personally it sounds to me like the OP's issue is not just related to camber but more likely too much toe-out (if tires are wearing excessively on the inside). The negative camber would have to be off by a few degrees (-3 or -4 degrees) to be the sole cause of excesssive, short term tire wear. These cars don't get that kind of negative camber from lowering springs alone unless there are other bad components or something is bent. Link to comment Share on other sites More sharing options...
