JCviggen Posted December 22, 2008 Report Share Posted December 22, 2008 The autobox doesn't like high rpm's though, better do a manual swap if you want to rev it high...with fuel cutoff you mean RPM limiter then? Not load limiter as I thought you were referring to that. Link to comment Share on other sites More sharing options...
flyfishing3 Posted December 22, 2008 Report Share Posted December 22, 2008 yeah, fuel cut off/ rev limiter.the map i have raises the cut off.i don't have a good dyno run to show numbers, but whats interesting on the runs i did get, the HP was still increasing right up to cut off. Link to comment Share on other sites More sharing options...
JCviggen Posted December 22, 2008 Report Share Posted December 22, 2008 Moving up the rev limiter is no problem, getting the box to shift later if you're not locking it in a gear though is something a bit different unfortunately Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted December 22, 2008 Report Share Posted December 22, 2008 Moving up the rev limiter is no problem, getting the box to shift later if you're not locking it in a gear though is something a bit different unfortunatelyI will be working on my evaluation this week since I will have all the tools to do it correctly. I will say one thing straight away. This tool is NOT for everybody. There is a learning curve, and a somewhat steep one at that. Basic knowledge of an internal combustion engine, the effect of advance, combustion temperature, compression ratio related to boost and introduction of fuel at high boost levels are a must. It is extremely sophisticated in the sense that you are tuning rpm ranges based on load, this is a large table that effects hp and torque throughout the RPM and load range. Be prepared to spend a fair amount of time fine tuning your car, and building a new engine if you FAIL.Alrighty then who's interested! Link to comment Share on other sites More sharing options...
JCviggen Posted December 22, 2008 Report Share Posted December 22, 2008 Of course it could still save a lot of time and effort that peeps can actually flash their own ECU, even if the images are made by someone else (you for example) :) Link to comment Share on other sites More sharing options...
Boost_Junky Posted December 22, 2008 Report Share Posted December 22, 2008 Exactly, we can all share tunes as well, right? It's just a file.I'm taking mine to a porsche tuner here in town anyway. I want it to be flexible and cost effective. I need it to be able to tune my car effectivly through M4.3, so I do not have to go stand alone. Link to comment Share on other sites More sharing options...
Chilled man Posted December 22, 2008 Report Share Posted December 22, 2008 I have a UK spec 850T5m ecu if anyone is intrested $150 + shipping Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted December 22, 2008 Report Share Posted December 22, 2008 I will be working on my evaluation this week since I will have all the tools to do it correctly. I will say one thing straight away. This tool is NOT for everybody. There is a learning curve, and a somewhat steep one at that. Basic knowledge of an internal combustion engine, the effect of advance, combustion temperature, compression ratio related to boost and introduction of fuel at high boost levels are a must. It is extremely sophisticated in the sense that you are tuning rpm ranges based on load, this is a large table that effects hp and torque throughout the RPM and load range. Be prepared to spend a fair amount of time fine tuning your car, and building a new engine if you FAIL.Alrighty then who's interested!ME!! ME!! I can't wait to get my hands on this bad bitch... Link to comment Share on other sites More sharing options...
mdlimy Posted December 22, 2008 Report Share Posted December 22, 2008 ME!! ME!! I can't wait to get my hands on this bad oh yeah!...agreed. i will read the manual and research for as long as it takes, i want this in my car! btw anyone know if i can send in my auto ECU and have it converted and have it work with my manual tranny without any cel's? or do i need to send in a manaul ecu? Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted December 22, 2008 Report Share Posted December 22, 2008 agreed. i will read the manual and research for as long as it takes, i want this in my car! btw anyone know if i can send in my auto ECU and have it converted and have it work with my manual tranny without any cel's? or do i need to send in a manaul ecu?Patience, is a virtue with this tool. My initial impression is that the versatility is there to really fine tune all ranges of driving. It's just going to take some time to get every detail just right.The auto ECU should be flashable to a manual. I will find out for sure. Link to comment Share on other sites More sharing options...
mdlimy Posted December 22, 2008 Report Share Posted December 22, 2008 Patience, is a virtue with this tool. My initial impression is that the versatility is there to really fine tune all ranges of driving. It's just going to take some time to get every detail just right.The auto ECU should be flashable to a manual. I will find out for sure.awsome thank you! im not sure if you would be allowed to do this but if you could ask if u could upload the manual for turbotuner im sure we would all love to read over it and start to familarize our selfs with it and learn everything a bit ahead of time. but again im not sure if you would be able to. Link to comment Share on other sites More sharing options...
dublin14 Posted December 22, 2008 Report Share Posted December 22, 2008 I will be working on my evaluation this week since I will have all the tools to do it correctly. I will say one thing straight away. This tool is NOT for everybody. There is a learning curve, and a somewhat steep one at that. Basic knowledge of an internal combustion engine, the effect of advance, combustion temperature, compression ratio related to boost and introduction of fuel at high boost levels are a must. It is extremely sophisticated in the sense that you are tuning rpm ranges based on load, this is a large table that effects hp and torque throughout the RPM and load range. Be prepared to spend a fair amount of time fine tuning your car, and building a new engine if you FAIL.Alrighty then who's interested!I think i will go this route, but i also think i will let my Mike at DL Motorsports her in burlington Ontario tune it for me on the Dyno as he has before.. Maybe best to let someone that does this for a living give it a go for a few hours. Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted December 22, 2008 Report Share Posted December 22, 2008 Edited for incorrect info.A manual car can use either a manual ECU or an auto ECU (without CEL on Eurospec)An auto car can only use an auto ECU.The finishing touches are being put on the manual and as soon as it is ready, it will be available for review. Link to comment Share on other sites More sharing options...
mdlimy Posted December 22, 2008 Report Share Posted December 22, 2008 The auto and manual ECU's are different. If you have a manual car you will need a manual ECU for a core or pay the core charge. The finishing touches are being put on the manual and as soon as it is ready, it will be available for review.sounds good! cant wait.ps more pictures =] Link to comment Share on other sites More sharing options...
Auburn T5 Posted December 22, 2008 Report Share Posted December 22, 2008 Hellz yeah.I know what my next purchase will be. Link to comment Share on other sites More sharing options...
