USMC850T Posted September 18, 2008 Report Share Posted September 18, 2008 To those whom have done this, what value did you use. I have a bad o2 sensor which is delaying my car from passing inspection and I'm completely sick of buying expensive parts for my 152K mile car. What value resistor should I use?? Link to comment Share on other sites More sharing options...
Ozark Lee Posted September 19, 2008 Report Share Posted September 19, 2008 The only condition where you can use a resistor to trick the ECU is if the heater on the sensor is bad. The book resistance specs are 1.5-2.5 Ohms at 68° and 6-10 Ohms at 660°. I would guess that a 5 Ohm would do the trick but I suspect that if the heater isn't working it will start throwing efficiency codes. The heater wires are the two white wires....Lee Link to comment Share on other sites More sharing options...
