MyCarIsRed Posted September 20, 2008 Report Share Posted September 20, 2008 sell it! :lol: seriously, that sucks man. Fingers crossed for ya. Link to comment Share on other sites More sharing options...
matt b Posted September 20, 2008 Report Share Posted September 20, 2008 Shipping a head across the US won't be cheap. I'd buy Pras' internals and rebuild yours. Stinks that it happened. Link to comment Share on other sites More sharing options...
turbomoose Posted September 20, 2008 Report Share Posted September 20, 2008 I bought a VR6 head on ebay when my Passats Timing Chain tensioner gave out.It was pretty cheap to ship, less than $50. Link to comment Share on other sites More sharing options...
Keaton85 Posted September 20, 2008 Report Share Posted September 20, 2008 You can ship depot to depot and its really cheap, I just shipped a bike engine from NM to ME for a hundred bucks.You can even bend valves by turning the engine over by hand... if your that dumb haha.Do the timing belt and water pump. see what happens then go from there. Just get it set-up so that it will run and see if it does without any trouble. Link to comment Share on other sites More sharing options...
Cal3thousand Posted September 21, 2008 Author Report Share Posted September 21, 2008 Ok... got everything off and a new water pump on.Now, how should I go about lining up the timing marks? I've searched, but all instructions assume that you lined up the marks before removing the belt. (which was impossible in my case.Currently, the exhaust mark is at like 2:00 and so is the intake mark. I know this is off, so which way to fix it first w/o bending valves? The crank mark is not visible at the current position.Please help... I need to have this put together tonight and I can't go forward until I line the marks up and replace all the pulleys and tensioner. Link to comment Share on other sites More sharing options...
matt b Posted September 21, 2008 Report Share Posted September 21, 2008 Ok... got everything off and a new water pump on.Now, how should I go about lining up the timing marks? I've searched, but all instructions assume that you lined up the marks before removing the belt. (which was impossible in my case.Currently, the exhaust mark is at like 2:00 and so is the intake mark. I know this is off, so which way to fix it first w/o bending valves? The crank mark is not visible at the current position.Please help... I need to have this put together tonight and I can't go forward until I line the marks up and replace all the pulleys and tensioner.Shoot Justin a PM, he has done them both with marks and without. Link to comment Share on other sites More sharing options...
Cal3thousand Posted September 21, 2008 Author Report Share Posted September 21, 2008 QUOTE (matt b @ Sep 21 2008, 11:57 AM) <{POST_SNAPBACK}>Shoot Justin a PM, he has done them both with marks and without.Thanks... Sorry I don't know Justin... what's his handle?I got the belt on and what I thought was the right timing. It sounds like crap and has a choppy idle at like 400-500 sounding like its gonna die. Kinda sounds like some dieseling.How do I know if I have bent valves vs. off timing? (My timing may be off due to hard to see marks on my 94 [can't find one on the cranksprocket, only on the serpentine crank pulley.]) Link to comment Share on other sites More sharing options...
WhiteT5 Posted September 22, 2008 Report Share Posted September 22, 2008 Thanks... Sorry I don't know Justin... what's his handle?I got the belt on and what I thought was the right timing. It sounds like crap and has a choppy idle at like 400-500 sounding like its gonna die. Kinda sounds like some dieseling.How do I know if I have bent valves vs. off timing? (My timing may be off due to hard to see marks on my 94 [can't find one on the cranksprocket, only on the serpentine crank pulley.])That's the one you use. Justin is Lil-Bo-Peep. Link to comment Share on other sites More sharing options...
Cal3thousand Posted September 22, 2008 Author Report Share Posted September 22, 2008 See anything wrong with this picture?:Here's a hint: Link to comment Share on other sites More sharing options...
turbomoose Posted September 22, 2008 Report Share Posted September 22, 2008 Just as I had said. How's it running?? Link to comment Share on other sites More sharing options...
Cal3thousand Posted September 22, 2008 Author Report Share Posted September 22, 2008 Just as I had said. How's it running??Like crap... I'm not sure if the timing is off because that plastic piece that you line the cams up with got sheared off by the belt..GOD... I wish I fixed it a week earlier.Now, I'm stuck wondering if I should take the car into a shop. I think I need to check the timing again and if it looks good. I probably have some bent valves.What's the best/easiest indication of bent valves? Link to comment Share on other sites More sharing options...
matt b Posted September 23, 2008 Report Share Posted September 23, 2008 Like crap... I'm not sure if the timing is off because that plastic piece that you line the cams up with got sheared off by the belt..GOD... I wish I fixed it a week earlier.Now, I'm stuck wondering if I should take the car into a shop. I think I need to check the timing again and if it looks good. I probably have some bent valves.What's the best/easiest indication of bent valves?What you just described but should also have some nasty noises too. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted September 23, 2008 Report Share Posted September 23, 2008 Needs an engine is my bet. I have a head with 8,000 miles on it if you wanna go that route. Doesn't seem like the best option though. I'd drop a motor in it or part it out. Sorry for the bad news :( Link to comment Share on other sites More sharing options...
Keaton85 Posted September 23, 2008 Report Share Posted September 23, 2008 WTF is with people and just installing engine instead of pulling heads and just getting them machined for cheap? Link to comment Share on other sites More sharing options...
Chilled man Posted September 23, 2008 Report Share Posted September 23, 2008 WTF is with people and just installing engine instead of pulling heads and just getting them machined for cheap? becuase for most pulling engine is easier head is only easier for people who have a good bit of engine work its still a bit of a PIA for me to do loloh and how is your drive shaft ? :P Link to comment Share on other sites More sharing options...
