mikie Posted October 10, 2004 Report Share Posted October 10, 2004 Last night I was taking some fast corners and all of a sudden a howling noise started to occure in right and left turns but ow the noise seems to be gone. I searched for some info and found that it could be the wheel bearings?? Also it's been awhile too since sometimes I get some creaking sounds when parallel parking/full lock turns...is this the wheel bearings as well??? Please help me out...1999 S70135 000kmThank You,Mikie Link to comment Share on other sites More sharing options...
Bay13 Posted October 10, 2004 Report Share Posted October 10, 2004 First thing to do is check the level of your power steering fluid, your car uses a green synthetic power steering fluid. Link to comment Share on other sites More sharing options...
mikie Posted October 10, 2004 Author Report Share Posted October 10, 2004 First thing to do is check the level of your power steering fluid, your car uses a green synthetic power steering fluid.←Sh*t...it's below the add mark...opps. Thank you so much. Is it safe to drive for another day (say 20km)?Mikie Link to comment Share on other sites More sharing options...
Bay13 Posted October 10, 2004 Report Share Posted October 10, 2004 No problem just top up when you can. Least you know what the noise is more than likely from, a lot of steering movement should bring on the noise. Link to comment Share on other sites More sharing options...
blandis Posted October 11, 2004 Report Share Posted October 11, 2004 Creaking may be steering stops. A little grease on them will stop it. Bay 13 has directions. Link to comment Share on other sites More sharing options...
mikie Posted October 11, 2004 Author Report Share Posted October 11, 2004 Thanks guys for your help, I've meant to put grease on the stops after reading it on Bay 13, I will do that rite now actually. Thanks again,Mikie Link to comment Share on other sites More sharing options...
