bmx9854 Posted September 29, 2008 Report Share Posted September 29, 2008 I've got lowering springs and 17" pegs and picked up some 225/45/17 tires for cheap. What can I expect for issues with this combination? I have 5mm spacers I was thinking about putting on the rear and possibly rolling the fenders this weekend if necessary. The reason I didn't get 215s was because stretched tires belong on Vdubs.....haha. Any input would be much appreciated. Link to comment Share on other sites More sharing options...
JVC Posted September 29, 2008 Report Share Posted September 29, 2008 I've got lowering springs and 17" pegs and picked up some 225/45/17 tires for cheap. What can I expect for issues with this combination? I have 5mm spacers I was thinking about putting on the rear and possibly rolling the fenders this weekend if necessary. The reason I didn't get 215s was because stretched tires belong on Vdubs.....haha. Any input would be much appreciated.you will probably run into a cat, a possum and possibly a giraffe. Link to comment Share on other sites More sharing options...
Wagoneer855 Posted September 29, 2008 Report Share Posted September 29, 2008 you won't be too bad, 5mm spacers for the front would be a good idea. Just expect a lot of inside rubbing at full lock. Link to comment Share on other sites More sharing options...
bmx9854 Posted September 29, 2008 Author Report Share Posted September 29, 2008 you won't be too bad, 5mm spacers for the front would be a good idea. Just expect a lot of inside rubbing at full lock.So 5mm in the front as well as 5mm in the rear? Do I need to go wider in the rear?.........I like it wide in the rear!! Link to comment Share on other sites More sharing options...
bmx9854 Posted September 29, 2008 Author Report Share Posted September 29, 2008 you will probably run into a cat, a possum and possibly a giraffe.Do you think so??? Maybe I should invest in deer/cat/possum/giraffe alert whistle? Link to comment Share on other sites More sharing options...
T5power Posted September 29, 2008 Report Share Posted September 29, 2008 So 5mm in the front as well as 5mm in the rear? Do I need to go wider in the rear?.........I like it wide in the rear!!i was thinking about doing a cool combo like 5 in front and 10 in the rear so it looks like i'm running RWD :lol: Link to comment Share on other sites More sharing options...
Wagoneer855 Posted September 29, 2008 Report Share Posted September 29, 2008 So 5mm in the front as well as 5mm in the rear? Do I need to go wider in the rear?.........I like it wide in the rear!!I would go 5 in the front and at least 10 in the rear. I'd go 15 in the rear and roll the fenders. It really changes the look of the rear when you push out the wheels. With my winter setup I run no spacers in the front and 15mm in the rear with my cetus. Only reason I don't run them with my 18s is that i can't find anyone who makes extended tuner style lugs. Link to comment Share on other sites More sharing options...
Wagoneer855 Posted September 29, 2008 Report Share Posted September 29, 2008 i was thinking about doing a cool combo like 5 in front and 10 in the rear so it looks like i'm running RWD no, then you'll just have an even track. The front will still actually be wider then the rear. 10mm in the rear with no spacers in the front and you'll have a pretty even track. You'll have to go with some pretty aggressive spacers in the rear, wider rear tires with some major fender rolling to get a RWD look. Link to comment Share on other sites More sharing options...
T5power Posted September 29, 2008 Report Share Posted September 29, 2008 no, then you'll just have an even track. The front will still actually be wider then the rear. 10mm in the rear with no spacers in the front and you'll have a pretty even track. You'll have to go with some pretty aggressive spacers in the rear, wider rear tires with some major fender rolling to get a RWD look.hmmm scratch that then lol. Link to comment Share on other sites More sharing options...
Black Betty Posted September 29, 2008 Report Share Posted September 29, 2008 i bottomed out in the rear over bumps when i drove too fast with 225/45/17's and i was on a stock R suspension Link to comment Share on other sites More sharing options...
partsguy Posted September 29, 2008 Report Share Posted September 29, 2008 So 5mm in the front as well as 5mm in the rear? Do I need to go wider in the rear?.........I like it wide in the rear!!Sig material here, any takers???????? :lol: Link to comment Share on other sites More sharing options...
Wagoneer855 Posted September 29, 2008 Report Share Posted September 29, 2008 Sig material here, any takers???????? "I... like... big... butts and i cannot lie, no other brotha can deny..." Link to comment Share on other sites More sharing options...
