Ghost Shadow Posted September 29, 2008 Report Share Posted September 29, 2008 its a 99 xc with newer motor since the old one blew a head gasket.car will overheat in stop and go traffic. a/c on or off. Changed the followingfan relayt-statect w/pi think its the fan. fan worked this morning when i turn on the car, but when it overheated the fan was not on.what else do i have to change? what else is left? Link to comment Share on other sites More sharing options...
vegasjetskier Posted September 29, 2008 Report Share Posted September 29, 2008 Water temp sensor? Link to comment Share on other sites More sharing options...
Ghost Shadow Posted September 29, 2008 Author Report Share Posted September 29, 2008 that's the ECT = Engine Coolant Temerature Sensor.changed it already, from a known good running car. My 01 convertible. all the parts are swapped from my 01, the fan relay, t-stat, and ECT. new dealer parts are going back onto my 01 Link to comment Share on other sites More sharing options...
vegasjetskier Posted September 29, 2008 Report Share Posted September 29, 2008 Is there a relay before the fan? Link to comment Share on other sites More sharing options...
Ghost Shadow Posted September 29, 2008 Author Report Share Posted September 29, 2008 Is there a relay before the fan?all of our cars have them from 93 on. above the radiator, big fan relay. Link to comment Share on other sites More sharing options...
Chilled man Posted September 29, 2008 Report Share Posted September 29, 2008 sure the fan works ? thermostate is that new ? Link to comment Share on other sites More sharing options...
Ghost Shadow Posted September 29, 2008 Author Report Share Posted September 29, 2008 sure the fan works ? thermostate is that new ?i was going to head home today with the t-stat out and see if it overheats. I have a 10 mile drive home, all stop n go. just to check the t-stat. but the upper and lower hoes are hot.i think it's the fan going dead. Link to comment Share on other sites More sharing options...
Mesoam Posted September 29, 2008 Report Share Posted September 29, 2008 are you certain you don't have air in the system? Link to comment Share on other sites More sharing options...
vegasjetskier Posted September 29, 2008 Report Share Posted September 29, 2008 all of our cars have them from 93 on. above the radiator, big fan relay.Can you put a voltmeter on the relay output to see if power is going to the fan? Link to comment Share on other sites More sharing options...
Ghost Shadow Posted September 30, 2008 Author Report Share Posted September 30, 2008 Can you put a voltmeter on the relay output to see if power is going to the fan?well got home tonight and tested the following. input 12v is good, low speed and hi speed is good. two outputs are good, freaking fan was getting power. only thing left is the effin ground was bad. corroded plug. tested the black plug that sits closest to the fan and it was getting 12v on one side (power flowing thru the fan to thru the plug) and the other side nothing. tested my 01 vert and this wire had a constant ground. i was like effin mofo, the ground is no good. cut the plug off and soldered a new one in front my parts bin and viola, instant fan spinning! arrg, thank god i didn't blow another head gasket from the overheating!problem solved, case closed! Link to comment Share on other sites More sharing options...
